cleg
- Oct 14, 2011
I've made a video about M6 vs R3. But don't expect an answer "which one is better"
Thanks
How about battery life and single ended performance between both.
Can the M6 give out good deep bass?
Did you try ASIOHi again. Finally I was able to use the usb output to connect the M6 to the ODAC. The problem is the ODAC (usb powered) requires more power to work than the M6 is capable of giving. It doesn't work unless you cheat the M6 by using a powered USB hub between both devices. It even works when just placing a non-powered usb hub between them.
I still have another question to ask here. Has anybody tried using the M6 as an USB DAC and succesfully play DSD files not converted to PCM? What I'm trying to do is use Foobar2000 to play native DSD files directly to the M6. I wasn't able to do it. I think I have all the required drivers installed in foobar but no sound at all. PCM works perfectly. Any suggestions? Thank you in advance.
Got my M6 today, first impressions are very good, however I have two questions....
1) how do I get Spotify on to the Dap?
2) any ideas why the DLNA doesn't pick up my nas? The fiio app on my phone does perfectly yet the M6 doesn't see it at all (WiFi etc all connected correctly) - no media servers are found apparently
Thansk, I assume ES file explorer would also be a download APK?
Thanks, apologies for the questions - do I download the APK file to the root of the SD card and find it that way?
Do I delete the APK file afterwards?
