Wow, I've had the same problem for a couple of weeks now. I thought it was just me. Could it be firmware related?The exact thing happened on mine! After a month the lines are gone.. I am baffled
[FiiO M6] Portable High-Resolution Lossless Music Player,Embracing A Wireless Future
superuser1
Beats me! Now my screen is absolutely clear without any lines.. magic?! Sorcery! Who knowsWow, I've had the same problem for a couple of weeks now. I thought it was just me. Could it be firmware related?
magnificientako
- May 1, 2006
You shouldn't compare apples to pears. ipod classic has an ordinary audio output like phones. Moreover it does not have android operating system and many connectivity features. But in my opinion, they could make a device with a big battery instead of a small device.The sound is nice but needs constant charging.A 12 year old iPod classic which ain’t much bigger can do at least 4 times the Fiio. Where’s the progress?
salla45
- Mar 12, 2014
Erm...(happy to be proven wrong with any of these BTW)
- Bluetooth - LDAC and a host of other bluetooth codecs,
- Wifi
- HiRes native playback for a host of different formats,
- NOT Itunes limited,
- USB C,
- MUCH better screen (4x the res and around 1.5x the size),
- No physical hdd,
- MicroSD port up to 1tb cards,
- arguably much better sound,
- around half the price in real terms,
- ability to run other software,
- much lighter at around 2.5 ounces,
- as opposed to around 5 ounces for the Ipod.
I'd call that progress.
PROblemdetected
Previously known as sakt1moko
I read a lot of post of MQA here.
Anyone could confirm that FiiO M6 does the total unfold of MQA from tidal? How it works, just from the app?
ryan750mhz
- Feb 12, 2017
My FiiO M6 is connected via USB to a FiiO Q1 Mkii, whenever a song is playing and i turn on/off the screen by pressing thenpower buttong buttong there's a crackling sound. Hoping this will be fixed on future updates
Ynot1
I'm posting here because Fiio updates firmware on their products and Fiio may just be the savior to save the day so to speak.
I listen to streaming, but I can only use limited gear that works through usb. I have other gears that take micro sd cards.
So in order to listen to music on all of the gears, it basically is too much work to port over music. You know, saving streaming audio
with software like Cinch ($20) and then saving it to microsd card. This is too much work and prohibitively costly.
We just want to listen to music. If daps can save fm radio, then daps can save streaming audio.
Please Fiio, make this happen in the next firmware release.
salla45
- Mar 12, 2014
I guess that's quasi-illegal at best? I'm sure that it's not going to get supported.I'm posting here because Fiio updates firmware on their products and Fiio may just be the savior to save the day so to speak.
OleJay
Thanks... worked wellDear friend,
Yes, try disabling usb audio out on the FiiO music app. Or restart the M6?
Best regards
Dear friend,I read a lot of post of MQA here.
The M6 does not support MQA.
Best regards
ObjectVoice
- Jul 30, 2015
Yep, I just got an M6 today as my about-town-player and have been enjoying it full well up to the point that I used it as a transport into a Fiio Q5 - and the screen on/off crunch/crackle when connected via USB is an instant & big issue. Very annoying and saddening. I just A/B'd with the Cayin N3 that the M6 was due to replace and screen on/off via USB into Q5 is silent. I'm on the point of returning this now. Anyone got a view about this? From Fiio or otherwise? I'm a huge Fiio fan, don't get me wrong - rocking the M11 etc.
It doesn't seem likely to me that this could be addressed via software updates - it seems more in the hardware camp (well, as much as I understand such things - which, in truth is not very much at all...)?
If Fiio has identified this as a fault which affects a subsection of M6 players I'd be perfectly happy to exchange this for one which doesn't do this since the format and execution generally is excellent.
Update: uh, weird: using the Fiio CL06 usb C to micro usb cable it crackles and crunches when you screen on/off. Using either of my other two USB C to Micro USB cables (which means that the M6 tries to charge the Q5 while pushing data) there's no crackle! Is it the the CL06 that's at fault rather than the M6? That'd be better!
Hifi-Junkie
Dear friend,
Best regards
It also does not the first unfold with the Tidal App? I thought I saw something in the fw changelog.
cristox
- Jun 6, 2008
The app does always do the first unfold, but the dac must be enabled to do the second unfold.
The dac in the m6 id not able to do the second unfold.
So you can play MQA in the Tidal app on the m6, but not as good as possible.
Zukubi
- Feb 19, 2015
so it means trying to play master quality waste of bandwith or storage. good to know that.
Zukubi
- Feb 19, 2015
@FiiO
Is Pandora Radio posibble to be white listed?
