HiFlight
Does anyone know if the whitelisted Viper app works with streaming sources such as Spotify and Tidal?
How can I access the storage/SD card after connecting the M6 to the computer: https://www.fiio.com/newsinfo/139021.htmlokay, I have a small problem, how do I copy the files to be sent to the Fiio email? I don't seem to know how to get access to the root folder...
Good enough for me, thanksDear friend,
Regarding the white list of 3rd-party apps on M6/M9: https://www.fiio.com/newsinfo/152463.html
We could report to the engineer about the APP you mentioned. But we could not promise the APP will be added or not.
Best regards
You could connect the M6 to the computer first for reading those files.
Best regards
Dear friend,This one, I know.
My issue is root folder. I cannot access the M6 system log because the file is in root folder and does not appear in Windows Explorer
M6 the best choiceI'm after a device to use with Bluetooth for portable audio. Considering this one, m0, R3 and m5. What would be the best one to go with?
hey, i was the Shanling m0, will the m6 be good upgrade only for SQ?
I went from the M0 to the Fiio M7 and though they sound similar the M7 does sound better across the board but not a huge difference compared to the M0. I demoed the M6 and actually prefer the more neutral M7 sound. So it really depends on your taste and if you want to spend more money. Power wise the M6 is a better match to the M0 though the M7 has more than enough power for me. No offense to anyone else but I really only trust what I hear with the headphones I use so sounds better can be very subjective.
It might help if you let us know what headphones you are using as they will play the biggest part in determining what sounds better.
