FiiO M6-Ultra-Portable Inexpensive Smart Hi-Res Player, Wi-Fi, AirPlay, FiiO Link, USB DAC, USB audio out, aptX/aptX HD/LDAC/HWA/SBC
Discussion in 'Portable Source Gear' started by FiiO, Dec 12, 2018.
164 165 166 167 168 169 170 171 172 173
175 176 177 178 179 180 181 182 183 184
  1. magnificientako
    I have no idea, but it's worth a try.
  2. FiiO
    Dear friend,
    Thanks for your feedback. We will report to the engineer and assess about that first.
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  3. dfung
    This is great info! I'm very new to this game. So you're saying a better set up would be a DAC/AMP with superior BT codec will improve the sound on the BT headphones? While having that same DAC/AMP connected to a phone or tablet via cable?
  4. Daiyama
    The sound quality is not necessarily improved, as the sound quality is determined by the BT codec of your headphone. If your headphones have a weak codec you need to upgrade them too. Before fiddling around with DACs and AMPs, you should check which codec your headphone uses.
    dfung likes this.
  5. dfung
    I have the MEE Audio BTX2 plugged to a pair of BGVP DM6 - https://www.meeaudio.com/BTX2/
    It doesn't have LDAC. Does it mean it's not that great?
    Someone suggested Elecom LBT-HPC1000RC
    It has LDAC and other codes. So more = better?
    https://www.amazon.com/Elecom-Compatible-Bluetooth-LBT-HPC1000RC-products】【Ships/dp/B07CZMN5VJ
  6. Daiyama
    Also not necessarily, as the whole headphone determines which sounds better to you. LDAC should sound better within the same headphone compared to other headphones. If you like the sound of your BTX2 I would not worry to much about the used codec. But if you like, you can test the Elecom and hear if you like them more but this get a bit off topic here and should be discussed somewhere else.
    dfung likes this.
  7. cristox
    M11 has updated Firmware...
    ...when will the M6 get it, too?
  8. FiiO
    TQuartic and mono-type like this.
  9. abitdeef
    Nice! Neutron on m6? Sweet!
  10. salla45
    good job,. thanks @FiiO for the update. Search is fixed :)
  11. mikp
    warning..
    just received the m6 and installed an apk with adb mentioned prevoius here. Then updated firmware, and this method no longer works.
    Also cant downgrade firmware-
    Fiio , it should be able to downgrade the firmware
  12. mono-type
    Finally, the much awaited update has arrived. Nice to see some of the requested apps like Pulsar are finally being whitelisted.
    Nice to see Neutron and PowerAmp on the whitelist, too, though I wonder if we could ever use the paid versions of those apps....
  13. Daiyama
    Super Sweet (or is this only available in the paid version?)
    Neutron Music Player 2.11.0-ARM64
    2019-07-24
    * New:
    - iBasso DX220: Filters and Gain support;
    - FiiO M6-M11: hi-res & DSD support;
    - App icon shortcuts;
    - Fast switch to media category inside the media library tree;
    - Touch-based filter response tuning.
    * Improved:
    - SACD ISO format;
    - hi-res driver compatibility;
    * Idle notification can be silenced now.
    ! Fixed:
    - MQA track not restored to original frequency if Oversample=On;
    - hi-res may be lost on LG V30-V40 if changing frequency;
    - Network -> Buffer Preload not saved.
  14. abitdeef
    Some neutron action :) with the peq engaged this is the best sounding tiny player.
    greenflash likes this.
  15. abitdeef
    I think if you already have neutron licence you can validate it.
