alex5908
Joined.Can someone please compare M5 and iBasso DC02 in terms of SQ?
Hello, I have a question. I would like to use the M5 for running and want to know if there is any way to fast forward or rewind the player without using the touchscreen? Wondering if there are button combinations that would work?
UPDATE: I found the answer!
You can only advance to the next track or reverse track by tapping and holding the volume + or - button (as @Ichos stated). There is no way to ff or rw.Hello. Would You like to share with us, how did You resolve this question? After I saw Your post, I got hope and went figure (or rather: gone figure...), but eventually I had to give up.... Please, tell, how to fast forward or rewind with side buttons? Sometimes there is a need to ff some tracks in longer mix-sets though...
Could you remind the engineers again that the bug with Russian tags still has not been fixed in the new firmware update?The engineer may need to fix some major issue first.
Hi, thank you for your advice. We will try to do what you expect.Right. Anyway, I think it would be more than great, if in the next updates of M5 firmware, Fii0 could give us an option for the alternative using the long press of the volume buttons, I mean - not only to play the next or previous track, but the other choice: to be able to fast forward or rewind. Especially since a lot of us are listening music via bluetooth (TWS), where we can switch between tracks on the very headphone yet. Damn, this litlle M5 baby could be then almost my perfect player ever (!)
For now, doing this while running or even walking is a little bit cumbersome, taking into consideration small display (still advantage though!), thick fingers and a short and thin ff/rewind playline.
Dear friend,WoW, thank You in advance for concerning my advice ; )
BTW - why after rebooting my M5 Baby from deep sleep, the first track I play has always an half second interruption every one second, like some kind of hiccup? This is very strange, because it stops breaking and starts to play properly only when I skip this first track, You know - when I do that and go back to this first track or any track at all, it's clear and everything is fine then. (????)
do someone know , when the new "watch case " is avaiable ?
Will be available soon on amazon and aliexpress and some local shop if our distributor ordered.
What is the real difference between the pulled 1.3.0 and the new 1.3.2 ?
Also anyone have issues with it saying no SD card in slot after turning it on even though there is a card in there?
