FiiO M3, Ultra-Portable|8G+64G|2.0" 320*240 TFT|50mW|FLAC/APE/AIFF|In line control|OGG, MP3, AAC, WMA |24 Hours|HiFi Earbuds
Sep 11, 2015 at 5:31 AM Post #31 of 2,001
Cards of 128,200 GB FAT32 formatted won't work James?
Since the physical limit is with SDHC SD 2.0 standard at 32 GB and the M3 supports 64 GB which is the SDXC SD 3.0 standard, SDXC supports up to 2 TB. It's like with a old Sansa Clip+, this tiny player as born in time without any 64, 128 oder larger SD cards. But if formatted to FAT32 there is no problem to use up to 512 GB SD cards (with microSD to SD adapter) with the sansa clip+. So if FiiO don't put a software limit, all 128, 200 or more SD cards on FAT32 on file browser mode should (it's only a guess) work fine, like the sansa clip+ example. Astell&Kern doing the same, the old first gen AK100 "offical" up to today only supports 32 or 64 GB cards, but in real world 128 or 200 GB microSD cards works fine.
Sep 11, 2015 at 5:43 AM Post #32 of 2,001
I think the value of an ultra small form factor is not talked about enough. Easy to carry in hand, fits in top shirt pocket. At this price folks are going to be a little less worried about rain getting on it. All this stuff IS supposed to be portable audio right? If it sounds great.....win-win. I'll get one. It gives the shuffle a run for the money, with just song capacity right out of the gate.
Sep 11, 2015 at 6:13 AM Post #33 of 2,001
total agree !
Sep 11, 2015 at 6:21 AM Post #35 of 2,001
  @JamesFiiO How is the volume controlled? Do the navigation buttons share this function?
If yes, will volume control only work in the "Now playing" screen?
it is very easy to control . we set the " now playing " as the main display menu so you alway can adjust the volume unless you are in the setting menu.
Sep 11, 2015 at 10:37 AM Post #40 of 2,001
16hours playtime....under 100bucks...this is probably IT. .
will it play AIFF files?
Sep 11, 2015 at 12:15 PM Post #41 of 2,001
Hello everyone.
I possess and enjoy several products Fiio.
There's something to Sansa clip zip+ , makes him unique and so far it has proved irreplaceable: their weight, their size and CLIP.
Hopefully the Fiio M3 has thought also to have those characteristics to really become his successor,
It would be formidable indeed have those features in a new device with the progress made in 2015 and manufactured by Fiio.
Written  in Google translator.
Regards
Sep 11, 2015 at 1:26 PM Post #44 of 2,001
Very Interesting James. I'm a HUGE fan of Fiio Products. Can you release any technical specifications Yet? Looks perfect to replace my wife's Ipod.
TWIN
