FiiO M17 (Dual ESS9038Pro, THX788PRO amplifier, at least 1200 mW, 6.3 mm headphone jack, expected release after July 2021 )
Mar 11, 2021 at 3:53 PM Post #121 of 392
justsomesonyfan
Depend on our test, the output power of M17 will be bigger than the others, in fact, I can say it is the most powerful portable DAP in the world, and there are room for us to improve the output power up to 2000mW+2000mW @ 32ohm cause the THX788 is design for desktop headphone amp. but we need to consider the battery life and the temperature.
please do 2k + 2k lol that'd be insane.
Mar 12, 2021 at 1:40 AM Post #122 of 392
JaviAl
Madrid, SPAIN
Yes, it's definitely photoshopped well. I still remember that device and the FiiO music player logo (older versions).
Its not photoshopped. Its a real Fiio render joke when discussing the number of microSD slots in the Fiio X7 1st Gen thread.
Mar 14, 2021 at 2:32 PM Post #123 of 392
EMINENT
Dallas, Tx USA
Can we get away from the need for a sim tool to remove the memory card?
Mar 19, 2021 at 10:24 AM Post #124 of 392
DarginMahkum
Berlin
@JamesFiiO , would it be possible to implement a system level PEQ for this, that can be applied to all applications like Qobuz, Tidal etc? As you already have the All-to-DSD feature, I guess you should have the software infrastructure to implement it. There is no DAP out there that implements a system level EQ properly and it is what many keep asking for (including me). Thanks.
Mar 19, 2021 at 10:58 AM Post #125 of 392
dsrk
Hyderabad, India
+1
Mar 20, 2021 at 3:50 AM Post #126 of 392
JamesFiiO
Sponsor: FiiO
we will try.
Mar 23, 2021 at 10:43 AM Post #127 of 392
bmichels
France, Belgium and Morocco
Do we have infos about SIZE and Weight to compare it to the DX220Max and my A&KSP1000.
thanks
Mar 23, 2021 at 11:12 AM Post #128 of 392
bmichels
I am glad they went for 6" display :)
I think that the new iBasso dx300 with its 6.5" is way too big .. for my taste ^^
where did you get that they use a 6" screen ? I see no mention of this anywhere !
Mar 24, 2021 at 2:17 AM Post #131 of 392
DarginMahkum
Berlin
I bought a Sony NW-ZX507 because it has an eq, which I thought was system wide. Imagine my anger when I found out it doesn't work usb out.
Oh, OK. I didn't really consider the EQ for BT and USB, and I am not sure if EQ for BT and USB would be possible, as I would expect the SoC / processor to be out of the equation, and BT or USB audio data to have a direct path to the DACs, without going through the SoC where the EQ runs. James can say more about it.
What I meant for system level EQ is for the applications, like Qobuz and Tidal.
Mar 24, 2021 at 3:52 AM Post #132 of 392
bmichels
I gathered some more infos: 600 grammes and 28 mm Thick, so it is very close to the 220MAX in size.
Mar 24, 2021 at 6:57 AM Post #133 of 392
DarginMahkum
Berlin
More photos of the replacement M line-up, M17 and K9Pro on the FiiO Weibo page:
https://weibo.com/fiio?refer_flag=1005055013_&is_all=1#_rnd1616582494930
Mar 24, 2021 at 9:16 AM Post #135 of 392
talan7
The Sony NW ZX507 does have system wide eq as it does work with Tidal, that’s why I got it. I wanted it to go the extra mile and work with usb out as well.
I believe the AK daps work l Iike the Sony and have system wide eq.
  • Top
