FiiO M17 (Dual ESS9038Pro, THX788PRO amplifier, at least 1200 mW, 6.3 mm headphone jack, expected release after July 2021 )
Feb 18, 2021 at 9:39 AM Post #76 of 263
hmscott
California
Not, in fact, we plan to remove the optical out from m17 because we can't figure out how to protect the optical connector.
James, perhaps the optical connection could be passed through a dock only connection? To protect the fragile optical cable only breakout the optical connection in an M17 dock? Pass through an I2S data out to the dock from the M17, and from the dock break out the Optical/Coax outputs? Perhaps even an optical/coax input could be fitted to the dock as well? The M17 dock would be a much more complex dock than the M15.
I was wondering about all of those connections on the bottom plate making it difficult to create a dock for the M17.
One of the nice accessories for the M15 is the DK1 dock. The M15 has a clean bottom plate with only the USB-C power/data connection making this possible.
It is very convenient to stand up the M15 on the DK1 dock for charging and desktop use. I like that the DK1 had separate connections for data USB-C and power USB-C, it would be really great if the new M17 had that capability as well.
Side or back connections? High enough on the back to plug in while on the DK1 (or similar) dock? Or perhaps multiple connections on the DK2 dock to passthrough all of the bottom connections on the M17?
Perhaps forgo the passthrough of all of the bottom plate connections for the M17, and support a desktop dock for the M17 with a centered USB-C power connecter on the bottom plate, like the M15 / DK1?
I'm very excited about the M17, but hoping a vertical dock can be fitted to the M17. :)
BTW, what version of Android is the M17 shipping with?
Feb 18, 2021 at 10:09 AM Post #78 of 263
hmscott
California
Yes I prefer full size SD vs micro SD.
Why? If the speed is the same or greater with the microSDXC and the microSDXC price is cheaper than Full SD, which has been my experience - more than half of my memory cards have been microSDXC - I put out for a bunch of full SD high speed UHS-II's for video recording, but other than that it's been microSDXC's for a while now.
Feb 18, 2021 at 8:04 PM Post #79 of 263
JamesFiiO
Sponsor: FiiO
It is true cause all the smartphone supports micro SD card and than the price is cheaper than Full SD.
https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com
Feb 18, 2021 at 8:32 PM Post #80 of 263
JamesFiiO
Sponsor: FiiO
1, It will be Android 10 .
2, Depended on our experience , only few people will like to buy a dock for a DAP, I like the idea and in fact we may the only DAP brand who make several dock device for our DAP but the sales it quite poor.
3, I will explain the reason why we plan to remove the optical connector soon!
Feb 19, 2021 at 5:03 AM Post #82 of 263
lostinthesauce
Interesting comments since it REALLY is 2021 right now, 1TB cards are available in both full-sized and micro flavors.
(Up to 100MB/s read) 1TB micro = $170
https://www.newegg.com/silicon-power-1tb-microsdxc/p/N82E16820301447
(Up to 120MB/s read) 1TB micro = $180
https://www.amazon.com/SanDisk-Ultra-MicroSDXC-Memory-Adapter/dp/B08HCPTMJG
(Up to 160MB/s read) 1TB micro = $225
https://www.amazon.com/SanDisk-Extreme-microSDXC-Memory-Adapter/dp/B07P9W5HJV
(Up to 100MB/s read) 1TB micro = $230
https://www.amazon.com/PNY-Elite-Class-microSDXC-Memory/dp/B08DL4899L
(Up to 170MB/s read) 1TB full-sized = $270
https://www.amazon.com/SanDisk-Extreme-SDXC-UHS-I-SDSDXXY-1T00-GN4IN/dp/B07VVMD5N7
Is it necessary to pay more for the extra speed or something?
Or maybe some of us might suspect that 1TB micro ones wouldn't be supported?
Would it be realistic to expect that 1.5TB / 2TB full-sized ones will be available in the (near?) future without a hefty price tag, at least initially?
Most likely I'm missing something, I just couldn't figure out why full-sized ones are somehow (still?) a necessity in year 2021.
I don't think that the speed is such an issue for the cards; I don't have any data but how many people simply shove the card(s) into their DAP to format it and then transfer the files that way resulting in the DAP being the bottleneck. Of even if they do the initial 'fill' of the card through a high speed reader update the files without taking the card back out of the DAP?
I don't have as large of a library as some people and the highest rips I have are the 16/44K rips that I didn't start doing until ~2010. Older music was ripped to 320K mp3 and I haven't been bothered to rerip it. Having thus exposed my luddite-ishness for not jumping on the latest and greatest formats as well as general laziness, I have 1.21 TB of music that wouldn't fit onto any single microSD card. On my old X5III I get around that by using one of the 1TB cards and an older 400GB. If a newer player made me choose what I couldn't put on it I'd be a tad disappointed as I treat my DAP as yet another back up. The request for full sized SD cards surprised me also as that market has seem to have been ceded to the really quick chips used in photographer/videographer kits that outstrip the microSD card prices.
Throw in the fact that the cheapest name brand 2TB NVME drive, compared to the cheapest microSD card you listed, is only an extra $14 (or pay an extra 8% to double the storage space) it seems like a consumer friendly choice to go with NVME. I am not privy to licensing fees, controller costs/energy usage (with resultant heat production), and whatnot so perhaps there is a specific reason that Fiio is sticking with microSD. And since I am a right nosey bastard I thought I'd ask.
Feb 21, 2021 at 6:17 AM Post #83 of 263
FooFighter
Germany
Reading through this thread it seems that some initial assumptions about the red light at the side don't come from tube glow, right?
So it will be a pure solid state DAP like KANN or DX Max, correct?
Feb 22, 2021 at 4:06 AM Post #85 of 263
seeteeyou
Living encyclopedia of product accessories.
Just do a search on "NVMe" and let's see what we're getting
https://www.qualcomm.com/search?query=NVMe
Could we actually find NVMe here?
https://en.wikipedia.org/wiki/List_...processors#Snapdragon_630,_636_and_660_(2017)
Or here?
https://www.qualcomm.com/products/sdm660
https://www.qualcomm.com/media/documents/files/sdm-sda660-product-brief.pdf
How about here?
https://www.qualcomm.com/products/snapdragon-660-mobile-platform
https://www.qualcomm.com/media/docu...pdragon-660-mobile-platform-product-brief.pdf
Not even PCIe was mentioned, let alone NVMe
https://www.cpu-monkey.com/en/cpu-qualcomm_snapdragon_660-1830
Snapdragon 660 was launched back in May 2017 and what do we expect? IMHO we're talking about DAP manufacturers here, not miracle workers or magicians etc.
Feb 22, 2021 at 4:26 AM Post #86 of 263
JamesFiiO
Sponsor: FiiO
Yes, it is pure solid state DAP.
Feb 22, 2021 at 5:14 AM Post #87 of 263
lostinthesauce
Or here?
How about here?
And yet manufacturers build boards with the 660 that offer m.2 (using pci-e).
https://www.winmate.com/Product/IQ30
Feb 22, 2021 at 5:19 AM Post #88 of 263
DarginMahkum
Berlin
