FiiO M15 Audio Player | Dual AK4499EQ | 7490 mAh Battery | 64 GB ROM | $1299.99
Jan 30, 2020 at 12:42 AM Post #766 of 3,939
dsrk
Hyderabad, India
This is your opinion, mine is different, aside of sound, it was slow, had poor battery life and broke micro SD cards. It's all on its head-fi thread. But, whatever, it's history.
About m15, how is tidal used on it? Does it have direct support or it is installed using downloaded apk? Now I use uapp on my smartphone and a pioneer dap, but without play store, it wouldn't be possible to install it.
Opinion is one thing and fact is one thing. The fact is it was the first DAP to have full version of Android with Google Play, game changer.
Jan 30, 2020 at 1:45 AM Post #769 of 3,939
musicinmymind
Jan 30, 2020 at 2:23 AM Post #772 of 3,939
DarginMahkum
Berlin
Guess you going on a portable gear buying spree ?
I only need one IEM, most probably this time custom, as I have fit issues with most of the IEMs and I don't want to deal with tips. Hopefully next week I will try some...
Jan 30, 2020 at 2:43 AM Post #774 of 3,939
Jim Bobber
Hey Guys, just checking there should be no difference between the 2.5mm out and the 4.4mm out right? I mean I terms of power? Have a 2.5mm cable for my HD800s’s.
Jan 30, 2020 at 2:44 AM Post #775 of 3,939
DarKu
Reviewer at Soundnews
Bucharest, Romania
Great, was worried balanced out was to powerful! Likely getting the M15 on Saturday, thanks for your reviews!
Indeed, balanced out is incredible powerful. Just make sure to use low gain and disengage the "over-ear mode" with your IEMs. Always check the volume position before plugging your headphones, I almost fried some IEMs :)
Jan 30, 2020 at 2:46 AM Post #776 of 3,939
DarKu
Bucharest, Romania
2.5mm and 4.4mm are identical in terms of power delivery. However, 4.4mm has a bigger surface/contact area and as a result will offer a slightly smaller resistance, I would use only the 4.4mm output with full size headphones.
Jan 30, 2020 at 2:48 AM Post #777 of 3,939
Jim Bobber
Thank you!!
Jan 30, 2020 at 2:56 AM Post #778 of 3,939
DarginMahkum
Berlin
The good thing about this DAP (and I think should be the same also for other FiiO DAPs using the same SoC), Qobuz runs very smoothly, downloads are fast, I was able to immediately connect to my 5GHz network, without having to change the frequency band. The whole experience is so far very positive.
There were some complaints about the amount of RAM - 3GB. I am downloading over Qobuz and also the FiiO player application is running and still it is using less than 1 GB of it.
Jan 30, 2020 at 6:40 AM Post #779 of 3,939
Launedernatur
Switzerland
What is "over-ear-mode"? I can't find such a setting.
