FiiO M15 Audio Player | Dual AK4499EQ | 7490 mAh Battery | 64 GB ROM | $1299.99
Jun 27, 2022 at 9:19 PM Post #3,916 of 3,941
FiiO
Sponsor: FiiO
Guangzhou,China
Done. Factory reset. Reapplied OTA downloaded from the site. When the device is turned off, it doesn't recharge.
Dear MusicalDoc8,
Did you check via another USB cable and charger as well? We could not located the issue without checking. But if the issue remains after factory restore, it seems to be a hardware problem.
Best regards
Jun 28, 2022 at 1:15 AM Post #3,917 of 3,941
MusicalDoc8
Italy
Multiple chargers and multiple usb cables. But chargers regularly when turned on. Also, if battery goes to zero i have to wait for it not being able to turn on at all before it starts charging again, because it forces it to kind of ''reset'' internally. I think it is software or once the battery was depleted i'd have no way to recharge it.
Dear MusicalDoc8,
Best regards
Aug 14, 2022 at 1:14 PM Post #3,919 of 3,941
MusicalDoc8
Italy
Hi I am getting very low battery life from my M15. It gets depleted in just about 2 days from full charge without even using it at all. Is this normal? Can someone confirm?
It depends on what you keepi in background. Such a piece of hardware would be better turned off when not needed, possibly keeping the battery between 10% and 80%.
Aug 14, 2022 at 2:00 PM Post #3,920 of 3,941
Gymboy
Ireland
Exactly, mine M17 is turned off when not in use, best. Turns off very quick, no need to be on stand by.
Aug 16, 2022 at 7:07 PM Post #3,921 of 3,941
Mooses900
Cincinnati
I am Having a issue with my m15 when I load music on it from my desktop, it sometimes loads on the sd card/internal memory, but sometimes it only scans and loads the artist and maybe a few songs maybe it doesn't load any. Has anyone have had this issue.
I have also formatted the sd,still doesn't make any difference.
Help
Aug 18, 2022 at 5:46 AM Post #3,922 of 3,941
MusicalDoc8
Italy
Help
What file type are those songs?
Aug 19, 2022 at 2:44 AM Post #3,924 of 3,941
FiiO
Sponsor: FiiO
Guangzhou,China
Help
Dear friend,
Do you mean reading the music files in the computer? Or are you using the DLNA function in the FiiO Music app? You could contact us via support@fiio.com about that as well.
Best regards
Aug 29, 2022 at 11:58 AM Post #3,926 of 3,941
MusicalDoc8
Italy
happened to me. use a wood
Hi
More have or had this that m15 wil not switch between 3.5mm and 2.5mm/4.4mm balanced output any more ?
Sinds short time i got no sound out 3.5mm and it stay in balanced out all time.
@FiiO
toothpick and gently rummage around. the ''pin'' that ''feels'' when the jack is inserted is probably stuck. happened to me once. if you have a light and patience you can see it, otherwise gently use the point of a wooden toothpick till you find the pins.
Aug 30, 2022 at 10:28 PM Post #3,930 of 3,941
FiiO
Sponsor: FiiO
Guangzhou,China
Hi
@FiiO
Dear friend,
There is a detection switch at the rear of the 4.4mm headphone jack. So the issue may happened because of the dust in the switch. After repluging the headphone for a few time, the dust between the spring pieces of the switch may get lost. So the product work fine again. You could consider adding a dust plug for preventing this problem.
Best regards
