Don’t all the prices in the EU include VAT?
Yes, but what does it change?
It would just mean the price is 20% higher in the EU than US with out anything else taken into accountYes, but what does it change?
Is the ak4497 a big difference to the ak4499?
Trying to decide between waiting for the m15, (ak4499) or getting the YinLvMei A2. (using ak4497)
Yes I believe they’re lower in distortion and are current output rather than voltage. That requires additional components, additional design and packaging efforts to get a voltage output.
according to digikey ... the cost of the ak4497 is $51 and the cost of the ak4499 is $84 to customers like you and me... it will be cheaper to fiio for bulk commercial customer...Is the ak4497 a big difference to the ak4499?
With your Abyss you probably need the Dx220 max or the YinLvMei A2 (4.2vrms Single-ended, 8.4vrms balanced)
I’ll be comparing the M15 to my mojo with the Diana Phi once the M15 arrives, I haven’t heard the M11 but I liked the mojo more than the IBasso dx200 with any amp if that gives you a referenceI'm actually listening with the Abyss Diana v2 right now plugged into the M11. It has to be on High Gain, but most songs I can listen from 95-120 on the volume slider.
I think the deciding factor would be whether or not there is a marked difference in sound quality between the M11 and the M15.
