FiiO M11Pro | Dual AK4497 | THX AAA 78 Headpone Amp | 5.15" 18:9 720P | Exynos 7872 | 3G Ram+64G Rom |
Discussion in 'Portable Source Gear' started by JamesFiiO, Sep 9, 2019.
41 42 43 44 45 46 47 48 49 50
52 53 54 55 56
  1. Adnan Firoze
    Any comparison between the M11 Pro and QP2R (sound wise, not feature)?
    cr3ativ3 likes this.
  2. Shareknow
    Hello everyone,
    Ordered the new M11 pro from fiio official site. will reach soon.
    please recommend headphones, over ear, to use/match with m11 pro. After spending on M11 pro i only have a limited budget.
    Among these Audio technica MSR7B and AKG K712 which will be a better match with m11 pro sound quality wise.
    Any other headphones that i can purchase within this budget that are better than these?
    I don't have the budget for senheisser 660s or the Hifiman Sundara.
    Thanks in advance.
  3. jmills8
    Koss Porta Pro
  4. Shareknow
    Hello dear jmills8 ,
    thanks for the recommendation.
    if u can elaborate, that why you recommend these over the other two, MSR7B and K712, that will be really helpful in making the decision.
  5. FiiO
    Dear friend,
    Yes.
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
    ayang02 likes this.
  6. someyoungguy
    If you’re interested in the HD660S you might want to consider the Sennheiser/Drop HD58X. Much cheaper price for a similar headphone.
  7. Dmitry89
    In-channel IEM headphones are not interested?
  8. Shareknow
    Hello,
    Which IEM's will you recommend with the m11 pro and why?
  9. Shareknow
    HD58x not available here.
    Any other headphones?
  10. Dmitry89
    I would recommend taking the Fiio FH5. They have very good sound, powerful low frequencies, expressive mid and pleasant high frequencies. The sound itself is voluminous with a good construction of an imaginary scene, when listening, you get the feeling that you are listening to good full-sized headphones.
    What kind of music do you prefer to listen to? (Genres)
  11. kdphan
    another annoying bug @FiiO
    When using Qobuz on M11pro, when one track is finished playing, the next track will have a loud static sound. Doesn't go away if i press FWD. I can only pause it, wait and then play again.
  12. szore
    Hi @FiiO : question, I had to reinstall windows, but now when I plug in the Pro, the Fiios driver shows up in explorer, but not the actual storage drives. I installed the windows driver, rebooted but it still does not show drives. It's possible I may have to install Mother board USB driver package, I don't know if I installed it, tho did install mobo chipset drivers... Any ideas?
  13. KC33
    Are you using the Fiio player?
  14. kdphan
    Using Qobuz.
  15. KC33
    I mean are you using the Fiio player when you listen to Qobuz
52 53 54 55 56
