FiiO M11Pro | Dual AK4497 | THX AAA 78 Headpone Amp | 5.15" 18:9 720P | Exynos 7872 | 3G Ram+64G Rom |
Discussion in 'Portable Source Gear' started by JamesFiiO, Sep 9, 2019.
15 16 17 18 19 20 21 22 23 24
26 27 28 29 30 31 32 33 34 35
  1. FiiO
    Dear friend,
    Thanks for the kind feedback. Please send email to us with the log files if the issue(
    A: The logs files can be grabed from firmware 1.0.4 or above. So when the certain problem happens on the M11 PRO, please go to " Settings ->About device" , and continually tap “Model number", until the prompt "Have save output log to built-in storage" appears. Then please wait for about 20 seconds, and go to M11 PRO's internal storage, then send the two log files ""M11 PRO-kernel-xx.log" and "M11 PRO-system-xx.log" to us for further analysis.
    Please be noted that, please do not reboot the M11 PRO before you grab the log files, because the log files will not be gotten after reboot.
    ) happens again.
    Thanks in advanced!
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  2. FiiO
    Dear friend,
    Please check whether you have turned on the all to DSD option? And is the M11PRO being charged? Or wearing the leather case?
    The M11PRO utilizes the dual AK4497EQ chip, and high power headphone amplifier, thus dissipating way more power than consumer DAPs typically performing computation, DAC and amplification all on the SoC. Apart from outputting more power to your headphones, a lot of this power is also dissipated as heat, thus causing the M11PRO to heat up in operation.
    Best regards
  3. szore
    I disagree the bass is better on the 1a.
  4. szore
  5. Dmitry89
    Lucky you! When I placed the order, only a dark green protective case was available. He is already on his way to me. honestly, I really miss him:blush:
  6. szore
    Why not just order the black now and return the green? There was only 4 left...
  7. Dmitry89
    Green also doesn't look bad for my taste. When the protective black case became available in the dd store, my order was already sent, so it is not possible to replace it.
  8. szore
    They accept returns, you were on Ali express right? But if you happy with geeen thats cool, i considered the green, its quite handsome!
  9. gLer
    He's going to sell the thing in a few months anyway, so probably not worth the bother :p
  10. szore
    Oh my god! You're so cynical!
  11. szore
  12. gLer
    Not really, he said as much himself. The Pro is only a stepping stone for the M15 for him...
  13. Dmitry89
    I assume that the M15Pro will be born no sooner than in 6-7 months, so I will have time to fully enjoy the M11Pro.
  14. Dmitry89
    The M11Pro is an excellent device, but I decided to get to the end, so when the M15Pro comes on sale, I will buy it.
    Shareknow likes this.
  15. jmills8
    Ok , you got the M11 Pro and you will buy the M15 Pro. Good for you. Once one buys a new dap one can post 5 times about it and end it there. Are you going to continue repeating that you have the 11 Pro and how you love it so much that you waiting for the 15 Pro ? Once you do get the 15 Pro then post 5 more times how great it is then stop.
