FiiO M11Pro | Dual AK4497 | THX AAA 78 Headpone Amp | 5.15" 18:9 720P | Exynos 7872 | 3G Ram+64G Rom |
Discussion in 'Portable Source Gear' started by JamesFiiO, Sep 9, 2019.
6 7 8 9 10 11 12 13 14 15
17 18 19 20 21 22 23 24 25 26
  1. gLer
    Again you seem to be confusing THX Cinema (which keeps sound consistent between home theatre and cinema devices), and THX Mobile (AAA) which is a technology for amp modules in mobile gear. You should probably take the time to read more.
    VanLifeHiFi likes this.
  2. gLer
    I have to wonder how much you’re tweaking the sound to get it to the point of distortion? Also, many IEMs/headphones don’t take too well to EQ, and many albums are beyond EQ help. Just curious here, not criticizing. One trick I was taught when it comes to EQ is to EQ down, not up. That way you’re avoiding clipping from the start.
    VanLifeHiFi and dsrk like this.
  3. Daiyama
    First rule of EQing. Always down never up!
    If something is to much than one can reduce it with an EQ and if you want to increase something reduce everything but the frequency range which you would like to increase and increase total volume.
    But usually if something is missing, than it is the wrong equipment. :wink:
    That is why I was always a bit annoyed about the automatic 6dB reduction when activating the EQ in the old FiO music player as I usually decrease only.
    VanLifeHiFi, magina35 and gLer like this.
  4. gLer
    Nail on head!
    Daiyama and VanLifeHiFi like this.
  5. dsrk
    I mostly increase 2 - 3db at max but you can clearly notice the distortion in the new FiiO EQ because there is no PREAMP. You get the same distortion on almost all the Android Apps but they all have PREAMP to prevent the distortion.
    So, the fastest solution is to add a PREAMP.
    I have not tried the Lotoo or Colorfly but Cowon EQ never distorts even at maximum.
  6. dsrk
    There is no perfect headphone or DAP out there IMO. People like me can't go trying everything (I don't have an option to try a few here in India in the first place) in the market to see which suits me better.
    Get the one which ever is closest to your taste and adjust perfectly to your taste..be it pad swaping or AMP module swaping or EQing...
    So a good EQ is very much essential in a dedicated DAP IMO.
  7. duaned
    Totally agree! What is really the point of having an eq if it does not work as intended ( Fiio here)? I would be pissed if I purchased a new car and the air conditioning did not work as it should. Since Fiio cannot seem to get this right ( yet they still promote this +12db to -12db bull with their eq) they why bother putting an eq into the device?
    To also state that if you need to eq than you have the wrong equipment, what a silly statement!
    Everybody’s taste and hearing are different. Correct me if I am wrong, but headphones are not made to suit my taste, but for the masses. Trying out every single iem in the market is impossible, however there may be the perfect sounding non eq’d IEM’s out there but I am yet to find them and possibly not afford them. The option to add or subtract a dB or two here and there suits me fine, and the feature is there for this reason. Just like the old bass and treble controls we had before many of us were born.
    stefzulj and VanLifeHiFi like this.
  8. MWeston
    I wish to agree with those that say the Fiio EQ is hot garbage. :) When I first got my M11, I thought about sending it back because it sounded so bad (compared to what I had expected in my mind). I put it in USB-DAC mode and used the EQ settings from my computer and instantly fell in love with the sound of the balanced output on headphones that I knew very well. Shortly after that, I bought the Neutron app and it's been fantastic ever since!
  9. gLer
    Do you have EQ settings that you can share that to you make the M11 sound as good as it does? Would be interesting to try them and hear the difference.
  10. MWeston
    I have a dozen different EQ settings, sometimes multiples for each headphone depending on what I feel like hearing that day. I usually look up the response for the headphone and create a baseline around the Harman curve and then I tweak the bass up and slightly adjust a couple other frequency ranges if they don't suit my tastes. For example, the settings for my Aryas don't sound very good on my Z1Rs and the settings for my P1s sound awful on everything else. :) Most of my EQs sound too bright on my HD800s so that one has its own specific settings.
    It seems difficult to recommend an EQ setting to someone unless you have the same headphones. I tend to follow these rules:
    - Harman curve as baseline
    - boost bass up by 8 to 10dB depending on how bass heavy the headphone is on its own. Make sure frequency gain is crossing 0dB by 200Hz.
    - Sometimes giving a couple dB boost at 1-2KHz unless it is a loud spot on a particular headphone.
    - Usually a dip below 0dB to some level, depending on headphone, between 4-6KHz
    - A high shelf of a few dB or more above 10KHz unless the headphone is super bright already.
    - Preamp gain of -6dB with auto-level correction against clipping.
  11. Battlefier
    I really do not get why EQ is such important from that much people.
    I have never EQ my Fiio devices and I am really happy with the sound I get with my headphones.
    VanLifeHiFi and Dmitry89 like this.
  12. jmills8
    If you never had a threesome then you will never really know.
  13. Battlefier
    The can you explain what is the goal of alter the sound signature of a headphone?
    I personally buy a headphone for its personality and I do not want to alter it.
  14. gLer
    Some people are obsessive tweakers, some people like plug and play, some do a bit of both. It's as varied as the hobby itself. If you plug in your headphones and are happy with the sound, you don't need EQ. If EQ helps, great. It's a tool - use it or don't use it, it's up to you.
    VanLifeHiFi and Battlefier like this.
  15. jmills8
    You mean you eq by buying different amps , dacs , headphone , music format , ear pads , iem tips instead of using a eq ?
