FiiO M11Pro | Dual AK4497 | THX AAA 78 Headpone Amp | 5.15" 18:9 720P | Exynos 7872 | 3G Ram+64G Rom |
Oct 28, 2020 at 10:58 AM Post #1,562 of 1,928
When I plug my M11 Pro into my laptop, all I see is drive H, that contains two folders, MAC and Windows. I can't see the external sd card? It worked last time I tried and the card is visible to the player. Any ideas? I've done a full reset on the M11 Pro.
Oct 28, 2020 at 2:03 PM Post #1,563 of 1,928
Maybe you just need to set the player's USB mode to «Storage» instead of «USB DAC». On the other hand in this case I don't even see the M11 Pro as a drive on my Windows computer.
It may also help to reinsert the card – or to remove the player and reconnect it. Or to reboot your laptop.
Oct 28, 2020 at 4:17 PM Post #1,564 of 1,928
Any comparisons to desktop setups? I'm finding the Fiio M11 Pro comfortably competing with Apogee Element 24 interface - both giving slightly different flavours, but with very good performance.. impressive that a DAP can compete (both with DAC/HP out) with a high performing desktop kit at a close price.
I wonder how the m11 Pro compares to the RME ADI-2 (both use AKM chips)
Oct 29, 2020 at 5:45 AM Post #1,565 of 1,928
Dear user,
You would need to install the MTP driver before reading the storage in the M11PRO. You could read this FAQ for more information: https://www.fiio.com/newsinfo/312400.html
Best regards
Oct 30, 2020 at 10:18 AM Post #1,566 of 1,928
Dear user,
Which song in Tidal app is having the problem? And you could send the log to us for check:
The logs files can be grabed in the M11PRO. So when the certain problem happens on the M11 PRO, please go to " Settings ->About device" , and continually tap “Model number", until the prompt "Have save output log to built-in storage" appears. Then please wait for about 20 seconds, and go to M11 PRO's internal storage, then send the two log files ""M11 PRO-kernel-xx.log" and "M11 PRO-system-xx.log" to us for further analysis.
Best regards
It's not a particular song with Tidal, it's when you are starting any song that is on a different album from the one to which you just listened.
*However, I used Tidal the other day with my iPhone and realized it does the same thing, so maybe that's a Tidal issue.*
BUT, my M11 Pro still skips the first second of songs when using Fiio Music and playing local FLAC files purchased from HD Tracks.
Oct 31, 2020 at 8:28 AM Post #1,567 of 1,928
Dear user,
Best regards
I get this error message.
Oct 31, 2020 at 11:49 PM Post #1,570 of 1,928
I have a Fiio M11 Pro. I got a 3-month free Amazon Music subscription, but Amazon doesn't display the bit depth or sampling rate of its albums. Is there any way to determine that? If I'm going to buy their music, I want to know what I'm buying !
Do you subscribe to regular Amazon Music? Or Amazon music HD?
If it’s the HD service, you press the HD/ultra HD icon and it will tell you.
Nov 1, 2020 at 1:34 AM Post #1,571 of 1,928
I wasn't aware I had to choose when I signed up. Now that I'm signed up, is there a way I can choose Ultra HD?
UPDATE: I just found PREFERENCES and was able to sign up for HD. Thanks for the heads up. Now I'll try downloading to my Fiio.
UPDATE2: What ?! I downloaded the songs to my PC and I get a bunch of 2-letter directories that are empty ?!?! I can't put those directories on my Fiio! How do I get these songs into a format that works on Fiio ?
UPDATE3: OK. I see there is one folder created with the album files. PHEW !
UPDATE4: I don't mean to be picky (OK, yes I do), but Amazon lists "HD" as 16/44.1 ??? That's CD quality, not Hi-Res quality!
Nov 1, 2020 at 2:32 AM Post #1,572 of 1,928
Glad you have it all figured out. I’m on a three month trial myself. Also on a three month Deezer HD trial.
Hiby R6 Pro
Nov 1, 2020 at 11:10 PM Post #1,573 of 1,928
I got the same message when installing that driver. Do a search on youtube for the steps to flip a switch in the registry to get past it.
But I still needed to install the driver from my M11 in safe mode. Only then did it work. And my M11 doesn't show up as a drive letter, which eliminates using any type of file sync software. Or I don't know what I'm doing. Probably.
Nov 4, 2020 at 3:18 AM Post #1,574 of 1,928
Dear user,
You could try the following methods for installing the MTP driver in Win10:
Or run the driver from an administrator-enabled powershell window, right-clicking over the Windows symbol.
Then you will be able to install the driver and access to the player's internal memory and the card as well.
If you have found other method for this problem, you could share with us as well. Thanks in advanced!
Best regards
Nov 4, 2020 at 4:55 AM Post #1,575 of 1,928
I`ve discovered very curious problem. I`ve listened an album with MQA 24bit, but last song in this album was without MQA and its resolution is 44.1/16bit. When starts playing this last track, sound has correct time, but song speeded up and deep voice of singer sounded like voice of small girl, or better, like a Chipmunk. Do you know about this bug? Is any recipe how to solve this?
