Fiio M11 Pro $600 is coming - Will you Purchase it ?
- Thread starter Head-Fi'er
rubinstein
- Aug 23, 2013
I am seriously considering the M 11 Pro.
I currently own Cayin N5iiS DAP. How does M11 perform against Cayin N5iiS?
Sunova
- Jan 12, 2017
Question to owners: couldn't find it that quickly (also not on YouTube), but are you enable to open streaming services (Spotify/Tidal) within Pure Music Mode? Like you can with the AK's (CT10/SR15). Forget tot test this earlier. So that you do not have to turn of the music mode to open 3rd party streaming apps...
EDIT: I think I already found this on fiio.com. Sadly not possible.
rubinstein
- Aug 23, 2013
So for the first week or so my M11pro got really warm, not what I would call hot. Compared to a phone it was hot though so it might frighten people not aware this is a different piece of kit.
But with every recharge of the battery it lessened and now 3 weeks in it doesn't get warmer than ambient temps by much at all even after running as a usb dac all day.
Shame they didn't have patience to audition it for 30 days before jumping the gun on a return. I think a lot of people on this forum suffer from FOMO and have the wallets to back it up, bad combo.
Hi all,
I auditioned Fiio M11 pro and like sound quality of it comparing to my Cayin N5iiS. Hence, I got Fiio M11 pro yesterday. The unit gets warm while charging and playing music. It takes about 2 hours to charge this unit using usb quick charge. I am using 4.4 mm balanced cable for Shure se846 earphones.
I have the following concerns,
1. After charging M11 pro to 100%, I played music in M11 pro continuously using pure music mode, high gain, short delay sharp roll off filter and all to DSD enabled. Wifi and bluetooth were disabled. I used shure se 846 with 4.4 mm balanced cable. The battery was drained in exactly 5 hours (I used stopwatch to monitor this). According to Fiio website, the battery life is upto 9.5 hours. Why did battery completely drain out in 5 hours? What could I do in order to have battery life for about 8 to 9 hours?
2. The unit gets warm while charging and also playing music. Would this heating issue eventually reduce after few weeks? Should I be concerned about this?
I hope that anyone here would give some insight on the above issues.
Thank you.
jmills8
Previously known as bmiamihk, jmills2
Uuuuu , Try not using it on high gain. Dude its a 846.Hi all,
Thank you.
rubinstein
- Aug 23, 2013
ok, I have changed the gain settings to Low, thanks
KC33
Now shut off all to DSD, that eats up your battery more than anythingok, I have changed the gain settings to Low, thanks
Afsa
I got the M11 Pro like 3 weeks ago. Im using the Campfire Andromeda S and got a 4,4 mm cable for them today. Im sad to report that i can hear a quiet prominent hiss after playing music.
It was less apparent with the 3.5 mm cable. Is there anything i can do to decrease the hiss or is that just the way 4.4 mm ports work? Its my first balanced connection.
radarnigz5
a specific aftermarket cable (link on my signiture) helped me on my Andromeda non-S version to have darker background, tho i still hear the amp going off after playing a playlist or song
Shahram
- Mar 27, 2015
It's due to the very high sensitivity of the Andromeda. And apparently high noise floor of the M11 Pro (which I am not aware is a thing yet). If you need a black background with 4.4mm go with the Ibasso DX160.
Shahram
- Mar 27, 2015
Yeah their published numbers are on low gain. You only need high gain for a full sized headphone, and only if it has low sensitivity or high impedance or both.
And? Since we're a few months down the road now .. Is the SK-11 case still a good fit on the M11 PRO? No issues?
whoking
- Mar 22, 2004
Just ordered the M11 (non Pro version). We'll see how it goes before considering the Pro. Trying to save a few bucks. Now I have to sell some old DAPs......
cleg
- Oct 14, 2011
And my review of M11 Pro
