FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
post-15873848
Post #8,416 of 8,481
Jcar
I have Tidal too and mostly use it for ripping FLAC, which is easy to do with Tidal GUI. Is there a way to rip MQA files yet?
Honestly, I really don't know if it's worth the effort to mess with high rez audio. I will collect them if I encounter them, but I have quite a few high rez audio files and I've done blind taste tests with them and I cannot tell the different between 44.1/16 and anything higher (although, I can almost immediately spot the differences between 44.1/16 and most mp3 bit rates). I've even tried 192/24, and still can't tell the difference. I think high-rez audio is mostly placebo (and there have been randomized, controlled, trials that back up the fact that humans cannot hear beyond around 44.1 - 44.8)), although I'm sure many here will strongly disagree.
post-15874009
Post #8,417 of 8,481
maxipein
I haven't been following this forum or updates about the M11. However, after one of the recent updates, suddenly my album art doesn't show up and the player crashes constantly when I'm playing playlists.
Did something happen? Is this a known issue?
I don't think it is. Try clearing the player's data and if that doesn't work, try a factory reset.
post-15877646
Post #8,418 of 8,481
DjBobby
Land of Chocolate and Watches
Need help with the bluetooth.
Tried to connect new bluetooth earphones, but the M11 doesn't let me do it because it infinitely keeps trying to connect to the previous ones used. That earphones are off, not active, but the M11 is still kind of searching for them, although there are plenty of other BT devices listed. Tried few times restarting the player, restarting the BT setting, nothing. The M11 always get stucked on that single connection forever.
If I tap on any bt device listed, I can choose "forget" or "unpair", but not on the active one. Tapping on the device name in the list which is in the process of "connecting", doesn't open that menu.
Any help much appreciated.
post-15879627
Post #8,419 of 8,481
FiiO
Sponsor: FiiO
Guangzhou,China
Guangzhou,China
Age
13
Website
www.fiio.com
Dear user,
The 'connecting' of this device would not stop after waiting a few minutes still?
Best regards
https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com
post-15879873
Post #8,420 of 8,481
snapandslide
London
London
So, the latest Tidal update seems to trigger MQA a lot more than before. I'm up to around 50% success rate - this is me playing music with hifi level quality, so bypassing Tidal and internally the M11 doing its thing.
Only one weird situation/song - playing a Masters track while in hifi quality, Tidal switched to playing the quality to Masters. No idea how/why.
Hopefully we'll get more consistent MQA triggering, as it certainly sounds better!
Well, that whole MQA worked for like 2 listening sessions and now nothing. The tracks which triggered before, absolutely no success now. Sigh, on the verge of just accepting we won't have MQA working on Fiio's latest gen devices.
post-15879921
Post #8,421 of 8,481
DjBobby
Dear user,
Best regards
I was impatient to wait few minutes. At lest never had this issue on the smartphone.
What I found out for sure is that it keeps trying to connect after waking up from the deep sleep standby and also after the reboot. Good news is that I managed to stop this infinite connecting after completely shutting down, charging the unit full and then turning it on after few hours.
post-15880011
Post #8,422 of 8,481
DjBobby
Dear user,
Best regards
OK, "connecting" started from itself again. Now I wanted to see how long does it take. It is already over 25 minutes spinning and trying to connect.
post-15883206
Post #8,423 of 8,481
FiiO
Sponsor: FiiO
Guangzhou,China
Guangzhou,China
Age
13
Website
www.fiio.com
Dear user,
Would you mind trying the factory restore to check whether it helps?
Best regards
post-15883426
Post #8,424 of 8,481
sbelter
Were you actually getting 44.1kHz and non-44.1kHz files to finally trigger the MQA indicator? And now, nothing at all? Playing back with Hifi selected rather than Master (to avoid software decoding)?
Everything seems to be the same for me - still only 44.1kHz tracks as well as occasional multiples (nothing 48kHz-based).
post-15883456
Post #8,425 of 8,481
DjBobby
Dear user,
Best regards
Thank you very much.
I did the factory reset last night and now everything seems to work fine. Starting adding slowly bluetooth devices, until now no problem.
post-15883524
Post #8,426 of 8,481
snapandslide
London
London
Jup was getting 44.1 and non 44.1 to trigger. But given up and just using through UAPP now. To my ears Tidal in general (non MQA) sounds much better through UAPP. So just going to stick with that.
One for people here, with UAPP - do we need to enable bit perfect for MQA? I notice I still get the mqa logo in the status bar with bit perfect off (despite UAPP before the track playing saying that bit perfect needs to be enabled). My own theory is UAPP detects the M11 can do all the unfold itself and so doesn't matter.
post-15884395
Post #8,427 of 8,481
anemotoad
UK
UK
Has anybody had any issues with dead pixels on their device? I’ve got five or so develop having bought it a few months ago which is a shame - is this a common thing, and does anyone know if it falls under warranty?
post-15891119
Post #8,428 of 8,481
Airsculpture
English but living in Fredericton, Canada
Had mine about a year and nothing.
I would contact FiiO.
post-15892670
Post #8,429 of 8,481
FiiO
Sponsor: FiiO
Guangzhou,China
Guangzhou,China
Age
13
Website
www.fiio.com
Changes and improvements about new APP for M series players are as follows :
1. Brand new v3.0 design, with an overall upgrade on visual effects and interactions, all for better listening;
2. Added Simplicity White and Deep Black themes;
3. Added a new option, "Unlimited", to the "File size limit for album art" setting;
4. Improved the speed of scanning songs;
5. Improved the USB Audio compatibility and also added support for FiiO Q3;
6. Miscellaneous improvements.
FiiO Music app-V3.0.1 for M series Android players: Click here
How to update the FiiO Music app:
1. Search and download FiiO Music in the App Store on your device!
2. Or Set the device to storage mode and connect to computer, drag the downloaded FiiO Music (.apk) to the device. Then disconnect the connection and enter ES file manager, find the FiiO Music app in internal_sd and click install.
If you have any problem in the latest version, you could uninstall the app and use the previous version. Or send email to support@fiio.com, we will reply when we are back to work in October 6th.
post-15892880
Post #8,430 of 8,481
DjBobby
I could download the new version of the app from the Google Play store, but the installation failed. "Can't install FiiO Music".
Users Who Are Viewing This Thread (Users: 3, Guests: 7)
