FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
post-15794282
Post #8,326 of 8,481
FiiO
Sponsor: FiiO
Guangzhou,China
Guangzhou,China
Age
13
Website
www.fiio.com
@FiiO I am getting really bad playback with DSD files now. I have ensured nothing else us running, no WiFi/BT, rebooted. The DSD files that played back fine pre-patch are now breaking up. Ideas?
Dear user,
Would you mind sharing your music files to us for check?
Best regards
https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com
post-15796395
Post #8,327 of 8,481
mlavende
UK
UK
Anyone else find their M11 runs really hot since the latest firmware update?
Currently trying to roll back to 1.0.9 to see if it makes a difference but I don't remember it being this hot previously
Thanks
-Mat
Reactions: megamoz
post-15796828
Post #8,329 of 8,481
mlavende
UK
UK
back on 1.0.9 and after resetting the Fiio music app all seems fine. It gets warm but doesn't seem to be as warm as under 1.1.0. Nothing scientific though, purely going by touch. Maybe it always did get hot and I never noticed - I usually have it in a case. Removed it for now to check.
-Mat
post-15797479
Post #8,330 of 8,481
megamoz
Italy
Italy
-Mat
it is slightly warmer, you’re right. i noticed that, too.
post-15800504
Post #8,332 of 8,481
YouAreGoForTLI
Taurus–Littrow
Taurus–Littrow
Thanks
-Mat
Mine recently *** itself, went dark (couldn't turn on/off and screen was blank) and got super hot about10 minuets after it crapped out. Im also having 1.1.0 issues ranging from minor to this.
post-15800533
Post #8,333 of 8,481
mlavende
UK
UK
I didn't get the shutdown or lockup but it was very hot. Rolled back to 1.0.9 and now don't have those problems.
Maybe some issue with the current latest release...
Thanks
-Mat
post-15800742
Post #8,334 of 8,481
HiFi47
Yogyakarta
Yogyakarta
Thanks
-Mat
I will do the same. I just installed the new version and my apps are crashing continuously and the battery consumption got even worse. Fiio should have some beta users before they give out new updates. It becomes with every update more unstable.
post-15801061
Post #8,335 of 8,481
Phil B
For those that are having issues with the new FW. After installing did you reset the device? So far my device is running fine (of course I just jinxed it), and all I did was install then reset.
Hopefully Fiio will reply soon.
post-15801075
Post #8,336 of 8,481
jdtenny
USA
USA
Reset how? Presumably FW updates do some kind of soft reset when they install.
post-15801180
Post #8,337 of 8,481
Phil B
Fiio always said after installing to reset the device. Its in the settings under backup and reset, then factory data reset. It brings the unit back to factory default but will not erase the sd cards. I have had glitches in the past with other FW and once I reset it cleared it up. Its worth a shot if your having issues, but you WILL have to reinstall whatever apps you had installed.
post-15801225
Post #8,338 of 8,481
jdtenny
USA
USA
Ah thanks, I'd forgotten. It's been a while since I've done an FW update, and I'm holding off on 1.10 until the current noise about problems dies down.
post-15801286
Post #8,339 of 8,481
Phil B
NP. Hopefully that can help some guys out.
Users Who Are Viewing This Thread (Users: 7, Guests: 8)
