[FiiO M11] Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Jun 3, 2020 at 9:16 PM Post #8,116 of 9,013
Mark-sf
California
Does anyone know where one can get the new SK-M11 case with the opening in the bottom as in this picture:
It does not appear to be in the Fiio Alixspress store.
Jun 3, 2020 at 9:25 PM Post #8,117 of 9,013
Mark-sf
California
Hi,
Recently upgraded my M11 to 1.0.9 and now I have no output on the 3.5mm socket. This is if the unit is set to PO LO or SPDIF. I've done a restarted, factory reset and its still the same on Spotify, FiiO Music or Tidal. Is their anything else I could have missed? It was working fine on 3.5mm headphones before. Unfortunately I can't test the 4.4mm or 2.5mm
Cheers
It has been previously suggested to hold down the Power+Play buttons for 15secs as this does a hard reboot and clears memory caches.
Jun 4, 2020 at 3:38 AM Post #8,119 of 9,013
Mark-sf
California
Jun 4, 2020 at 11:41 AM Post #8,121 of 9,013
Thx1326
Speaking of BluTooth...
I found these Fiio UTWS1 Blutooth adapters on AliExpress and this looks like the perfect device to turn my higher end IEM's into wireless/cordless. And the price is right at $49.00. My question is: What is BluTooth actually transmitting? I'm assuming that all the decoding is done in the M11 and this is just a digital broadcast of the results from the M11 to the BluTooth receiver??
So for the sake of keeping this simple with no brand of IEM's in question, let's say that the sound quality of the corded IEM's (balanced or unbalanced) - on a scale of 1 to 10 is a 10. What should the sound quality be through the same IEM's on these adapters?
Any thoughts?
Thanks
Jun 4, 2020 at 2:02 PM Post #8,122 of 9,013
Mark-sf
California
Jun 4, 2020 at 2:08 PM Post #8,123 of 9,013
Mark-sf
California
Any thoughts?
Thanks
You can check out their specs at https://www.fiio.com/utws1. Their highest resolution will be aptX which is limited to 16bits and 384kbps at 48kHz sampling rates.
Jun 4, 2020 at 2:30 PM Post #8,125 of 9,013
steamboiled
Thanks for the link. That is the old case with the opening at the top which I had previously found. The reason that the new one has the bottom opening is that inserting the jacks can cause the player to move out of the case. I also like the look better with the leather top.
Actually this is the link i used to buy mine some time ago, i believe FiiO just didn't update the pictures but try to drop them a message to confirm. Pic of mine below.
Jun 4, 2020 at 9:23 PM Post #8,127 of 9,013
Thx1326
At $49, they may still be very nice for traveling - I think I am going to have to pick up a set. M11 is on its way! Wednesday! Gonna be hard to part with the X5 - it certainly sounded sweet.
Jun 4, 2020 at 9:40 PM Post #8,129 of 9,013
Thx1326
I bought the LC-BT2 for bluetooth listening, as they support LDAC Bluetooth transmission to the FH7.
And to be honest, I can't hear a difference to the wired solution.
But I'm not the pro on these things. Just my very personal impression.
So which mode on the BT2 do you think gives the best sound? And... do the controls work with controlling the M11 or X5?
Jun 5, 2020 at 4:57 AM Post #8,130 of 9,013
FiiO
Sponsor: FiiO
Guangzhou,China
Hi, here comes the latest 0604 beta firmware for M11
Notice: this version is still under beta testing phase. If you have any problem, please feel free to contact us at support@fiio.com. Any suggestions would be greatly appreciated.
Download link:
M11->fiio-file.fiio.net/M11-ota-20200604.zip
Update note:
1.Added support for screen rotation (can be set in the pull-down menu or in Settings -> General. The screen will rotate upside down when this option is enabled);
2.Added global MAQ support (now the player supports 8x MQA unfolding even when playing MAQ tracks in third-party apps. However it not include Tidal, Tidal will update a version to adapt our product later);
3.Added a new function of hiding the un-scanned or empty folders in Folder view menu (can be set in FiiO Music -> Settings -> Scan for music. When enabled, only the titles of the scanned tracks will be displayed in Folder view menu);
4.Added album art display in Folder view menu;
5.Added quick-charge indication with a motion effect
6.Added 'File size limit for album art' function (can be set in FiiO Music -> Settings. And after selecting a limit, the album art image whose file size exceeds this limit will not be displayed);
7.Added volume and battery display in USB DAC and Bluetooth receive mode;
8.Fixed the issue where the Google account data could not be backuped.
9.Miscellaneous improvements on performances.
Best regards
