Airsculpture
Single card slot was a deal breaker for me
The brand is a no name card that was $30. - I bought it on a lark, because I also needed a new card for my camera. I am copying DSD songs to the card as we speak. Will know over the next few days if it was worth my time and effort. ( my PC does say it is close to 1 TB. )
I stream Tidal most of times so storage is a non issue for me. Sound quality though matters. M11 is great indeed but the Pro takes it a bit higher still. Especially when you are using sensitive IEMs.
I believe it's discussed here already but 500 pages uhh... I'll try to read through past pages as much as I can but right now I'll appreciate quick answer.
For quite some time I'm considering M11, and for my needs it's much better choice than pro variant or even upcoming M15. Mostly because of the price and dual card slot.
I have one concern though. Can anyone tell me how does the M11 pair with sensitive IEM in terms of white noise? My S8F is very picky and so far I'm getting hiss from almost every source I tried it with. Every but ES100, that is perfect combo IMO, it's dead silent, convenient and SQ over LDAC is fine.
If M11 + S8F produce white noise it will be absolute deal breaker for me, because I offten listen to quiet, ambiental, relaxing music and even the smallest amount of hiss is annoying and unbearable to me.
One more, has anyone tried Ifi Iematch? I believe it will clean up the noise and lower the volume, but will it change the sound signature?
Thank you for your answers
I don't use IEM's, but having read most of the 500 pages I would guess you only have to worry if your IEMs are below the supported resistence recommendation. I've read that IEM's below what FiiO says is the minimum recommended resistance will hiss. IIRC it's 16 Ohms, but please don't take my word for it. People with IEMs above the recommended resistance seem to be happy. Again, all anecdotal based on my reading of this topic.I believe it's discussed here already but 500 pages uhh... I'll try to read through past pages as much as I can but right now I'll appreciate quick answer.
I owned m11 , first of all it's a great dap probably the best bang for buck and it really doesn't have any major faults, great build, great ui, and sounds pretty good too ...but for me it did hiss with my andro s , now everyone's level of hiss tolerance is different and even though it did hiss a little with andro s it wasn't awful but noticeable....I sold mine because I found the audio on a dx160 both sig and black background to be a lot better , but the dx160 has awful bluetooth and not great wifi distance either plus less battery life , one slot etc etc ...hope this helps.
From what I have heard the m11 pro is better for sensitive iems.
Some advice!?Hello , my Q5 has died ( faulty 3.5) . Im thinking to buy M11. This will be my first dap. So i have one question , M11 will sound much better over an smartphone?! I have my music in flac , and i use Tidal.
It will as it has a better DAC chip than the one that normally comes in a smartphone. Plus it has more power to run your gear better.Some advice!?
I didn't realize the Q5 was a phone. I think the answer is "your mileage may vary". You're already ahead of the game by listening to flac files in stead of crappier lossy representations of the music. From a hardware perspective the M11 is hardware dedicated to the purpose of audio. Is the dac better than what's in your phone? Probably, as well as the tailoring of the rest of the hardware to respect signal leakage and so forth. It really comes down to which pieces of your signal chain are the weak links.Some advice!?
