FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Discussion in 'Portable Source Gear' started by FiiO, Mar 19, 2019.
Tags:
477 478 479 480 481 482 483 484 485 486
488 489 490 491 492 493 494 495 496 497
  1. Seancs14
    I have one cable that I can switch terminations on. So controlling for that, I don’t notice any difference in the SQ between 2.5 and 4.4. I’m firmly in the 4.4 camp for durability though.
    salla45 likes this.
  2. Airsculpture
    Downloaded media monkey which insisted on installing Google Play.
    Now can’t open APK Pure, just closes every time I try to open it. Solution would seem to be to remove Google Play but it’s not showing in the UI.
    Thoughts ?
    Update - uninstalled through settings/ apps and now can successfully open APK Pure
  3. Darren Cotter
    Is it me, or does the M11 have more treble emphasis than the X7ii with the AM3A? I'm using FH7 with the bass tips on both DAPs.
  4. darren700
    So I own an x5 gen iii that I primarily use with Dunu DN2000j (8ohm) iems. Using the latest modded firmware from a headfi user the x5 gen iii is still preforming quite well for my needs. I want to upgrade to the m11 but I am concerned by reports of hiss with IEMs. considering the impedance is quite low on the dn2000js I am concerned that the hiss will be very loud with them. Can anyone comment on the hiss that is present with low impedance iems? Thanks
  5. salla45
    thanks for replies ref 4.4mm vs 2.5mm. I got my BTR5 on Friday, been messing with that since then, lol. Stellar little device doing great work as both USB dac and BT; gives me a much more even playing field with my phones now competing with daps for everyday listening. Will ponder on the balance route. Cheers!
  6. FiiO
    Dear friend,
    The seller fails to help about that because you do not have the receipt, right? Did you contact us via support@fiio.com?
    Sorry for bringing inconvenience to you.
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
    majo123 likes this.
  7. FiiO
    Dear friend,
    Thanks for the feedback. We will report to the engineer for checking about that.
    Best regards
  8. FiiO
    SoundChoice and jaxz like this.
  9. x X x
    Changes in FW1.0.8:
    1. Added In-vehicle mode (Settings -> General -> In-vehicle mode, if enabled, the player will power on/off automatically when vehicle engine starts/stops and the FiiO Music app can also switch accordingly);
    2. Added manual item sorting for playlists;
    3. Added 'screenshot by three-fingers swiping down' function;
    4. Added a new play mode: play single once;
    5. Added playback position and track remembering;
    6. Added a new method to enable volume adjustment by swiping up in FiiO Music Now Playing screen, and also improved the volume bar operation (now you'll need to drag on the volume bar to adjust the volume instead of just tapping as before, so to avoid misoperations);
    7. Fixed the issue where the playback would fail in the new version of Amazon Music;
    8. Improved the effect of the equalizer and fixed the random equalizer failure issue;
    9. Improved the display of the FiiO Music background;
    10. Improved the display of the lockscreen album art;
    11. Improved the All to DSD function and reduced its power consumption;
    12. Miscellaneous bug fixed;
    13.M11 Pro: Fixed the issue where the player might power off automatically during audio playback if the power off timer is enabled.
    Ad.1
    It is also available from Now Playing screen.
    Ad.2
    Nice, but only available in earlier created playlists. But accessing it is not as intuitive as in other appliacations. Here you need to press and hold your finger to move a track on a playlist. Please consider adding a "visual button" with this functionality, such a classic android hamburger button (a lot of android applications have access to this functionality via mentioned "button"). Also will be nice have this possibility into Now Playing queue. Additionaly, please consider adding selected tracks/album/artists to current playing queue (as "Next" or "Add to queue" as last).
    Ad.5
    When playing a track and Fiio Music is shutted down, track position is not remembered.
    Ad.9
    Background quality looks better now :)
    Additionaly:
    Some time ago I asked about sorting tracks in Artist view, accessed via Now Plaing screen. Not track of artist are sorted alphabeticaly. Will be a much better with sorting tracks by albums of artist (and tracks of album ordered in album-configured order).
    Anyway, thank you for this new update. It is nice to know that after releasing M11 Pro, the "old one" M11 is still in upgrade process :)
    SoundChoice likes this.
  10. Mybutthurts
    @FiiO
    Many thanks for the fixes in new update.
    Amazon musicHD working nicely.
    :blush:
  11. moodsmaster
    Has anyone tested the eq? Is it working now? I can’t download the firmware right now, but I’m ver curious, because a good EQ is my missing feature for the Fiio music app
  12. Luke-
    @FiiO @JamesFiiO
    Anyone getting native playback on Amazon HD?
  13. MichaelOH
    I can't believe that sorting by album artist is still not supported in FiiO music....it's why I'll continue to use Poweramp.
    JRichardson1228 likes this.
  14. Airsculpture
    EQ seems as weak as it ever was to me, just my opinion.
    Back to Poweramp I go.
    Edit. I'm also getting occasional missing artwork in the FiiO player which weirdly shows up in Poweramp.
    Even reloaded the tracks and scanned them again. Still missing. Rectified myself by embedding the artwork again but I shouldn't need to when Poweramp just got on with the job.
    Anyway, it's the weak EQ that puts me off. Shame , as the UI has the edge over Poweramp, just about.
    Like I said back to Poweramp.
  15. Mybutthurts
    @Luke-
    Downloaded music. Shows as:-
    Streaming as.
    Although the 'currently playing at' values change due to my crappy 4g router/signal.
    From absolute rates right down to standard.
    Non Amazon Offline files in the app don't play at all.
