FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Discussion in 'Portable Source Gear' started by FiiO, Mar 19, 2019.
Tags:
466 467 468 469 470 471 472 473 474 475
477 478 479 480 481 482 483 484 485 486
  1. MachBot
    I've tried to use the M11 as a transport but the Samsung USB C to USB A male OTG adapter doesn't seem to work with my O2+SDAC.
    I thought the OTG adapter might be a fluke so I bought a USB C to microUSB cable since that's what they had at my local audio store and it seem to work just fine when I used it with one of their desktop amps. That doesn't seem to work either so I tried a powered USB C hub and finally that did the trick.
    It's worth noting both the OTG adapter and USB C to microUSB cable work on my phone, so it seem like the USB C port implimentation on the fiio M11 isn't providing power(or adequate power) in host mode to my dac.
    I'd be helpful if @FiiO can provide some input on this.
    On that note, I'm not able to get logs generated because connecting the dac to my m11 will result in the device doing a soft reset.
  2. oHOWEo
    I plugged mine into Arcam irdac ii via usb using the otg adapter that came with my Samsung s9, it worked fine. I also bought a usb c otg dongle that has PD power delivery to try and charge the fiio while it was connected to Arcam asynchronously, it would either charge or stream to the dac not both at the same time.
  3. MachBot
    It suddenly occured to me that the DAC portion of the O2+SDAC has to be powered using USB, so perhaps the USB C port on the M11 isn't able to provide more than 5v 500mA? That would also explain why it works only with the USB C dongle only when power is provided.
    @FiiO
  4. jdtenny
    To hook the M11 up to my old-ish truck which has no fancy stuff or built-in receiver for wireless, I use a the line-in jack that my radio has in the console.
    I've also experimented with the el-cheapo 12 volt gizmos that receive bluetooth and transmit FM radio to the receiver, but these can be a pain in the butt if you can't find an unused FM frequency.
    The line-in jack is best quality, not that it matters for me, my M11 far outclasses my truck's stereo system.
  5. szore
    Does it?
    showme99 likes this.
  6. Wyville
    Oh certainly, no problem there. :D
    szore likes this.
  7. mcook1970
    Hi oHOWEo,
    You can buy a balanced cable from the seller: mavismodz6 on eBay. He is based in the UK and can customise the cable for you with either a 2.5mm or 4.5mm connection based on your request. I have bought loads of cables from him over the years and have had no issues. I can definitely vouch that the cable I purchased from him for my P9s significantly improved using balanced over SE on my M11!
    pilgrimbilly likes this.
  8. pilgrimbilly
    +1 for mavismodz. Excellent quality and service.
  9. oHOWEo
    Thanks for the info!
    Adding a balanced cable won't make the headphones balanced correct?? Is the sound quality upgrade purly from giving the headphones more power out of the balanced port of the Fiio?
  10. vibin247
    The headphones need to have separate channels for each ear in order to benefit from the balanced connections on the M11. If your headphones have separate inputs for each ear, likely there is an OEM or third-party cable that will have the 2.5mm balanced or 4.4mm/Pentacon plug for that headphone.
  11. shinewallace
    Hello all, may I ask a question.....
    I have used M11 since May, but now my player keeps appearing the same problem:
    the player suddenly crash, mostly happened when I keep pressing "forward" several times to select the next song I wanna listen
    (no playlist setting, play all and random play)
    do you guys know the reason why? It's quite annoying to me.......
    or any third party player app can replace the FIIO player if it cannot be solved the above problem?
    Many thanks.
  12. Mybutthurts
    I have the HiBy app on my M11, works great for me when I use it. Also, use it as part of the work around do I can use Amazon music HD on the M11.
    There are others, that cost etc
    But happy with HiBy here.
  13. FiiO
    Dear friend,
    1.From the use of matching, Q5s must be more widely used, and the decoding specifications are higher; but M11 is a player which is a integrated solution.
    2.From the audio processing, the dedicated decoder amp is better than the same DAC player, just like the desktop machine principle, the comprehensive function of the DAP with amplifier products is average.If it is divided into three machines: player, DAC, amplifier so each machine is more expensive than the integrated machine because it is more dedicated. This is a special usage, so the sound quality will be better.
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  14. FiiO
    Dear friend,
    Did you try the factory restore to see if it helps?
    Best regards
  15. shinewallace
    Yes for sure. And thing still happened. May I know any possible reasons for make it like that so that I can try to fix it?
