FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Discussion in 'Portable Source Gear' started by FiiO, Mar 19, 2019.
Tags:
426 427 428 429 430 431 432 433 434 435
437 438 439 440 441 442 443 444 445 446
  1. FiiO
    Dear friend,
    Thanks for the kind feedback. We will report to the engineer for fixing about that.
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
    x X x likes this.
  2. FiiO
    Dear friend,
    You may send it back to us for repair or buy a battery for replace. But the repair may not be easy because you would need to disassemble the M11.
    Best regards
  3. mcook1970
    Thanks Simon. How would you describe the soundstage in terms of width and depth?
  4. FiiO
    Dear friend,
    You could try to download the app you mentioned from https://apkpure.com/, then copy the apk file of the qualified app to the M6, then open the File Management app, locate and click on the apk file to install it.
    Best regards
  5. FiiO
    Dear friend,
    Yes, the 32bits is max bit rate. And it keep showing 32bit in M11 when working as USB DAC.
    Best regards
    salla45 likes this.
  6. Mybutthurts
    Signed up for 90 day trial.
    Working fine so far, Bluetooth-ed to ruarks just fine. Quality ok
    Not sure of how to check actual rate of stream hi-res/MP3 etc
    Tried some artists/albums that are unobtainable on other streaming sites... 2 found out of 3 so far.
  7. simon740
    Im sorry..I only had M11 for one week, so cant comment on this...plus my IEMs not so good.
    Simon
  8. jdtenny
    Playback quality aside, my reservations about installing anything built by amazon is that it will spy on my device and try to sell me crap.
    Jujoe likes this.
  9. Luke-
    I have the app installed everything works till I try to play a song then it just keeps spinnning loads album art but won’t play tried reboots etc no luck....
    And I don’t think it bypasses androids audio
    My Hugo didn’t show correct sample rate momentarily when I press play
  10. phillevy
    Same with me
  11. totozero53
    @jdtenny
    Did you update the device with beta firmware floating around ?
    I’ve never had the issue myself but others told the update has fixed it.
    —- sorry it has been answered before !
    Didn’t refresh the current page and missed a bunch of posts.
  12. totozero53
    WAIT ?!
    Did you buy a new one Simon ? :cold_sweat::joy:
  13. simon740
    no no...
    You have this one now :relaxed:
  14. JerryLeeds
    I just downloaded a version of Netflix and installed it on the M11... Seems like there is a slight delay/sync issue with the playback sound. Any help or thoughts would be appreciated
  15. gLer
    Netflix is still quite good. YouTube is basically unusable if you need lip sync. Plex is actually very good. I've asked @FiiO to help fix the YouTube (and now Netflix) lip sync issue, but no luck. I guess for now, Android or not, a dap is a dap, not a movie player (even though the M11 ironically supports AptX LL which is meant to 'fix' this issue for BT headphones).
