FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Discussion in 'Portable Source Gear' started by FiiO, Mar 19, 2019.
Tags:
404 405 406 407 408 409 410 411 412 413
415 416 417 418 419 420 421 422 423 424
  1. MariusAB
    It would be nice that fiio could share what discharging speed is normal when everything is off. Ofcourse some processes are going in the background any way so it should discharge a little bit bit how fast it should go?. As i clearly remember that when i received my m11 with 1.05 i was surprised how unbelievable long it lasted when i left it with everything off. Anyway thanks everyone here to sharing their experience.
  2. Wyville
    I don't know, my wife nicknamed the M11 the "high-end Solitaire player". :sweat_smile: (She always steals my phone to play solitaire and when the M11 came in and I said it was Android she just asked... "But does it play Solitaire?")
    showme99, SoundChoice and steamboiled like this.
  3. Jujoe
    [​IMG]
    showme99 and Wyville like this.
  4. RikudouGoku
    seems like alot of people are following my guide, hope it helps and doesnt have too many english errors.
    szore, piscattore, Wyville and 2 others like this.
  5. jmills8
  6. fablestruck
    Thank you for your help.
    But how do I sign in from the Neutron app?
    I go to settings/ help/account.
    Then when I try to enter the information for pop3 I don't seem to manage to register it.
    (in the pop3 dialogue underneath there are 3 buttons. one that depicts something like an envelope, one that depicts the delete sign and one that depicts an X. If e.g. I write the 'pop3s://pop.gmail.com' and the hit the envelope button nothing happens. The same about Login & Password)
    What do I do wrong?
  7. Jujoe
    So sorry buddy I dont use neutron
  8. Nayparm
    Those buttons from left to right are 'Paste' 'Undo' and 'Clear' not for registering anything.
    If you have enabled pop3 in gmail then just type in the address, username and password pressing enter on your keyboard after each one. Neutron should have a progress bar at the top whilst checking and put a circle selector next to your account once it is confirmd ok.
    Try restarting neutron after (force close from settings, apps) and back into help, account to check.
  9. fablestruck
    Thank u for jumpin in for help.
    The password is my gmail account password?
  10. fablestruck
    It worked.
    Thank you both very much.
    Cheers
    Wyville, Jujoe and Nayparm like this.
  11. Jujoe
    No worries buddy happy listening :)
  12. cjfreitag
    I tried the BT DAC receiver functionality for the first time today. The M11 is primarily about audio quality for me, and I know that BT compromises that. But I have to say I really like being able to stream things from my iPhone (which has an unlimited data plan) to the M11 so I can listen to music or watch video using with the FH7s. I could do the same thing by using my iPhone as a WiFi hotspot connected to the M11 (and that works fine), but as good as the display and interface for the M11 are, I prefer navigating and watching on my iPhoneX.
    Overall, it just speaks to the quality and flexibility of the M11. I am finding it far more satisfying than my first DAP, which was an AK240.
    toddverrone and Jujoe like this.
  13. FiiO
    Dear friend,
    1. Lowpass filter mode: To set the filter modes: Sharp Roll-Off Filter, Slow Roll-Off Filter, Short delay Sharp Roll-Off Filter, Short delay Slow Roll-Off Filter, Super Slow Roll-Off Filter. For reference:
    2. Play through folders may be set to On to set the M11 to skip automatically from the last song in one folder to the first song in the next folder when playing from a folder listing.
    3. HWA is one kind of the Bluetooth codec.
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
    Vitandus and loungecat like this.
  14. noaid
    Hello, yesterday I found that Q5s does not handle DSD correctly. L and R channels are reversed when playing DSD. With PCM (flac,mp3,...) channels are correct
    Possibility how to check is with Fiio Music android application. You can do it with ANY DSD track you have.
    1. Play any DSD track on PC or elswhere.
    2. Note positions what is on the left and on the right.
    3. Play the same DSD track in FiioMusic - USB output Native settings
    4. You hear channels are reversed
    5. Switch USB output to DoP DSD over PCM.
    6. Channels are still reversed.
    7. Switch USB Output to D2P DSD to PCM conversion.
    8. Channels are correct.
    You can do this also with any other players which support DSD and switching DSD mode.
    DSD bitstream is sent to wrong channels, PCM bitstream is sent correctly.
    If you will experience similar channel reversing in Native and DoP mode comparing D2P then the same problem is also in M11.
    Will you please check this?
  15. Jujoe
    Sorry yo are having issues but maybe best to post in the Q5s forum.
    https://www.head-fi.org/threads/fii...spdif-line-input.902614/page-75#post-15113082
