FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Discussion in 'Portable Source Gear' started by FiiO, Mar 19, 2019.
Tags:
398 399 400 401 402 403 404 405 406 407
409 410 411 412 413 414 415 416 417 418
  1. krumplib430
    Unfortunately RE-EQ didn't work for me either (aurora store didn't work for me for non-free apps). But if you happen to only use TIDAL, you can try out CAPTUNE which was developed by sennheiser. It is a free player which has native support for tidal and it has a good EQ. Please be aware that captune EQ will apply the necessary negative pre-amplification so you might need to raise the volume after EQ. I'm not aware of any system wide EQ other than RE:EQ.
  2. Vitandus
    Yeah, it's the album/track selection UI that is where the difference really shows between Neutron and the others.
  3. Nayparm
    Well windows 95 looks pretty good to me :L3000:
    Screenshot_2019-08-18-14-07-52-668_com.neutroncode.mp.jpg Screenshot_2019-08-08-16-02-59-258_com.neutroncode.mp.png Screenshot_2019-08-18-14-14-20-313_com.neutroncode.mp.jpg Screenshot_2019-08-08-16-02-23-738_com.neutroncode.mp.png Screenshot_2019-08-18-14-11-00-422_com.neutroncode.mp.jpg Screenshot_2019-08-08-16-02-41-422_com.neutroncode.mp.png Screenshot_2019-08-17-11-31-22-725_com.neutroncode.mp.jpg
    BadReligionPunk and Jujoe like this.
  4. BadReligionPunk
    Yea Neutron has a lot of options to tweak the UI. I have tried to tweak it and have got some pretty good results, but I cant seem to get the wallpapers to work. @Nayparm. How do I do it? It has to be something easy that I am overlooking. Want to use this Image as the background.
    Doesn't work even if I set Neutron to use system background. It's obvious I'm confused as what to do. Worse case is that I listen to music. Not look at the software that plays it, so it's not a huge deal.
  5. hayder945
    Quick Question regarding the deep sleep feature, I have noticed an option for sleep timer and poweroff. But once I activate them it resets after it has powered off.
    So is this "sleep timer" the Deep Sleep feature? If so how do I activate it to put my device on sleep every time I stop using it.
  6. Nayparm
    It should be that plus setting the correct transparency in many of the colour settngs. I'll
    share my config later on.
  7. hldn
    Hey! Thanks for taking the time to post this. Will try CAPTUNE. About system wide EQs, I think there are many options but everything sucks and is max 5 bands... So far the only thing that worked was Neutralizer. It has a different approach but it sure helps.
    NotKunvinced likes this.
  8. DeejayAlex73
    I saw on Youtube a comparison between Ibasso DX220 and Fiio M11. Even the reviewer gave M11 the winner. But are we sure that M11 is better than Ibasso DX220? To me it honestly seems a bit strange, considering the audio DACs Ibasso owns. Does anyone have to comment?
  9. Jujoe
    If that reviewer likes the M11 more than DX220 fairplay to them, there is no wrong or right answer just opinion and we all got one :p
    I love my M11 and for the cost of the dx220 I was able to get a the M11 and FH7
    showme99 and Mybutthurts like this.
  10. DeejayAlex73
    I now own an AK SR15, do you say that with this M11 I could have more benefits in terms of audio quality?
  11. jmills8
    Yes
  12. DeejayAlex73
    installing Neutron anyway and doing some things obviously, or not?
  13. Luke-
    Hi
    Any links to how I can install Neutron player on my M11
    Cheers
  14. Jujoe
    Use the web browser in the M11 and install from the neutron website. there is a guide in the thread :)
  15. jmills8
    That can help , stock player is good.
