[FiiO M11] Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Aug 11, 2019 at 10:46 AM Post #5,957 of 9,019
Colors
Toronto
Aug 11, 2019 at 9:51 PM Post #5,962 of 9,019
SoundChoice
USA
The review highlighted the ability to transfer files via wi-fi to the internal memory. Does anyone know if wi-fi can be used to transfer files to the SD cards?
Thanks!
Yes.
Open up the included ES File Manager, Menu, Remote Manager, Turn On. You now have turned your M11 into an FTP server.
Then open an FTP app on your computer and transfer files over.
(The ... on Remote Manager allows you choose the root directory, so you can select the home folder (or SD card) which the FTP app will see)
Aug 12, 2019 at 1:14 AM Post #5,965 of 9,019
Raketen
Would you consider selling these? I would be interested.
FYI there are places/websites that can print it for you if you don't have a printer.
Aug 12, 2019 at 2:03 AM Post #5,966 of 9,019
gLer
Tatooine
Thanks!
I use Solid Explorer to connect to my music server via SMB, and can then transfer any file or folder I like to either SD card on the M11 via copy and paste. Works well, and faster than USB.
Aug 12, 2019 at 9:02 AM Post #5,968 of 9,019
Fukuoka, Japan
If connecting to my receiver Marantz 6012 I have been using the setting spdif out. What happens if I used line out for HiRes does it get downsampled before reaching the receiver ?
S/PDIF is digital. Line out is analog. When you use S/PDIF, you are sending a digital signal to the Marantz, which uses its internal DAC to convert it to analog. When you use the line out, you are sending out an analog signal, decoded from digital by the M11, and the Marantz is just amplifying it.
Aug 12, 2019 at 9:16 AM Post #5,970 of 9,019
Jujoe
Purgatory Hill
not really, Maybe a few, my printer is not a production unit. each one is about a 3 hour print on my printer. And i think shipping costs might make them cost more than they are worth.
IMG_20140207_124227.jpg My one Haha epic mess
No I cant print stuff it DEAD :p
