[FiiO M11] Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Aug 6, 2019 at 10:01 AM Post #5,776 of 9,019
RikudouGoku
Sweden
Thankyou for this as I want to get a set of T800 and was concerned about Hiss :):)
If you have a pc around then that is going to make more noise than the T800 :joy:
Aug 6, 2019 at 11:45 AM Post #5,779 of 9,019
spanner43
Corbett Oregon US
Has anyone tried this player with the Sennheiser 6XX headphones or the BGVP DM6??
yes i often use my senn/massdrop 6xx with my M11 around the house, I like the combo a lot. I use high gain and the volume up a bit 80+ but it sounds great to me.
Aug 6, 2019 at 8:42 PM Post #5,783 of 9,019
Colors
Toronto
It sounds pretty good.
Took me awhile to get used to the M11 sound signature, but I learned to appreciate it over time. It’s pretty transparent without too much flavour. Ideal for continuous listening without fatigue.
Aug 6, 2019 at 10:06 PM Post #5,784 of 9,019
NovaFlyer
Washington, DC
Aug 6, 2019 at 10:45 PM Post #5,785 of 9,019
FiiO
Sponsor: FiiO
Guangzhou,China
Dear fiio,
Waiting longer does nothing, reconnect the M11 also does nothing, the same issues exists, why don't all the folders show on both devices??
Best regards, me
Dear friend,
What about restart the M11? It seems to be a problem with the MTP driver because some other devices have the same issue as well. :cry:
Best regards
Aug 7, 2019 at 1:03 AM Post #5,787 of 9,019
spanner43
Corbett Oregon US
Love that stand.
Wish I could get one of those.
If you can get this link to a friend or someone with a printer, a high school maybe, it should be a fairly simple print. https://www.thingiverse.com/thing:3725259 .
There is about a dollars worth of plastic in it and it takes a couple of hours to print. I would be happy to print some up, the trouble is getting them out at a reasonable cost meaning shipping. Not wanting to make money on these
Aug 7, 2019 at 5:01 AM Post #5,789 of 9,019
MariusAB
Lithuania
Yesterday was in the shop with my m11 and nearbay was ananda on the table but sadly hadn't time to listen it. But last time i listened with m9 and even then i liked it a lot. Really high grade sound, total control and details but very natural tuning. With m11 it should be next level, will listen it perhaps in a few days so can say more.
Aug 7, 2019 at 5:26 AM Post #5,790 of 9,019
simon740
Slovenia (EU)
Ok. Thanks. I will wait.
regards,
Simon
