FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Discussion in 'Portable Source Gear' started by FiiO, Mar 19, 2019.
Tags:
281 282 283 284 285 286 287 288 289 290
292 293 294 295 296 297 298 299 300 301
  1. gLer
    I’ve tried HiBy (not bad, nice effects, crap UI); PowerAmp (excellent, almost as good as FiiO Music but much better UI and effects, and you can organize by album artist); Neutron (decent sound, high-res driver wasn’t working well for some reason, ultimately too fugly to keep). Eventually I just defaulted to FiiO Music, which for my purposes (no playlists, don’t care about random play, mostly play full albums by album or folder) is perfect and easily sounds the best out of any player on the M11.
  2. Nayparm
    What was your neutron hires driver doing? Were you using the 64bit version? Not had any problems. I also have it maxed out (for m11 dacs) outputting everything at 32bit 384khz :L3000:
  3. abitdeef
    Fiio is definitly the nicest, but like when I tried the more bass light P1 planar I had to use the peq on neutron to get them to sound similar to what I'm used to- akt8ieii
    The fiio eq and hiby eq didn't cut it. In the end they hurt my ears so it doesn't matter, but I do like the precision and flexibility of that peq. But I agree, over all, the fiio app is the overall best. The UI is so fast and fluid. Still cool I can have multiple players.
  4. gLer
    It was glitching and misbehaving, although to be fair I only briefly tried it and didn’t bother to troubleshoot. The UI was so ugly compared to any other player I just deleted it since I knew I’d never use it.
  5. abitdeef
    How do you max it out for m11 dacs? What settings. :) the thing has a gazillion settings
  6. abitdeef
    Lol, booted it out like a red headed stepson.
  7. Nayparm
    The gui is bit odd to start with but i've modified it and like it now. It really is the best sounding most powerfull app. The 64bit DSP PEQ is amazing. Glitch free here :L3000: I was ready for selling mine straight away when I used it with fiio music :ksc75smile:
    abitdeef likes this.
  8. Nayparm
    I can post settings tomorrow, or I can send config files.
  9. EvilJesus
    In browser settings under artist is an option to only show album artist. Hope this helps. 20190721_185925.jpg
    JRichardson1228 likes this.
  10. abitdeef
    Mucho thanks mate! Whatevers easiest:)
  11. lesale08
    Man, the BT function really is very battery efficient. Connected to my car for 2 hours on the road with only 1% consumption. Haven’t tried with any BT iem or HP though. Pretty impressive.
  12. Monztah08
    Now i have officially joined this gathering.
    Got myself my FiiO M11 and a pair of FiiO FH5.
    abitdeef and Ryokan like this.
  13. lesale08
    Congrats on the new toys. How are they so far?
  14. Monztah08
    I'm still trying to learn the gestures but i like it so far, its very responsive and fast. Its my first dap since 15 years. I don't have an extensive library of music (yet) so i mostly use Spotify. The M11 and the FH5 are high-end for me. I cant afford anything more expensive, but with all these features and sound signature i don't have to! :)
    The FH5 were a bit tricky to find a good seal with so i was missing a lot of bass, but after much trial and error i figured out that i have to use foam tips to get a good seal. Now it sounds like i want it. I guess im a bit of a "basshead". :p
    [​IMG]
    [​IMG]
    JRichardson1228, Tuneslover and Jujoe like this.
  15. x X x
    Hello there. I have got some proposals (and issues found) for Fiio App on M11.
    1. First of all, would you be able to modify (or give us a possibility to change it) a way how Artist shortcut works when accessing from Now Playing screen? Now it shows all Tracks of current Artist in alphabetical order. I will be pleased to see all albums of current Artist, eventually list of all albums and all tracks (similar way as eg. Tidal does it). Now, from my point of view, this list is a little useless. Please, add such functionality here.
    2. Maybe add us possibility to go directly to current track album using three dots shortcut on a tracks list? Now, there are 'Add to Favourite', 'Add to Playlist', 'Check track info', 'Delete song' and 'WiFi music transfer' shortcuts. 'Go to Artist' and 'Go to Album' would be very helpfull there too. 'Album' shortcut is available from three dots menu in 'Now Playing' screen and it is vere pleased to see it there. I found now that Album shortcut is also available by pressing album name above the playing buttons. Nice.
    3. I found that gesture of hiding Now Playing screen by swiping down is very sensitive, I have a lot of non-swipe gestures activated when accessing three dots menu from Now Playing screen, or when trying to press other buttons here.
    That is all for now. Hope your guys enyoing this great device!
