Finally got around to experimenting with using the M11 as a very bulky and expensive bluetooth receiver....and it's pretty good at it! I'd say LDAC streaming from S10+ phone to M11 gives me about 90% sound quality while providing a small uptick in convenience. I'm using Campfire Atlas with the M11, and I perceive the bass to be somewhat less pronounced via LDAC, but it still sounds very good. On a separate note, I got the (faux?) leather case today from Penon Audio, and it is a nice upgrade over the clear case that ships with the M11. I came close to sending the M11 back to Amazon a few days ago in favor sticking with my LG V35, but decided to give it some more time. I'm glad I did, it's a nice device and worth the asking price.
Thanks! To avoid 2-cable solution, I wonder if FiiO L21 cable is compatible or not... They list some of the older FiiO DAPs as compatible, but either M11 is not compatible, or the page for L21 was just not updated (yet?)... I wish they had a solution like the DK1 dock for the M11...
Weird, I was just looking into the same thing and about to post! It doesn't mention the M11 I guess as it pre-dates it but they are both TRRS 3.5mm. On the M11 adapter the tip and first ring at the end are unconnected - the sleeve and ring closest to it are used. I would hope they use the same connections...
It'll be nice to get a confirmation from @JamesFiiO whether FiiO L21 SPDIF Coax cable is compatible with M11.
Dear friend, Would you mind providing the music files having this issue and the detailed operation progress, log g files to support@fiio.com first? Thanks in advanced! Spoiler: how to get log files When the problem happens again, click model number option from Settings-about device for several time until ‘have save output log’showing up. Please send the files'XXX-kernel-xx.log,XXX-system-xx.log' from the root directory of the M1 to us for check Best regards
Don't know about the Sennheisers, but the Focal Elear sounds great and I can only get to about 50 on the volume wheel before it gets too loud. Elear is 80 ohm I believe, so not the same demand as Hd6xx, but I still bet the M11 would do a good job of driving them.
Dear friend, The 4.4mm output of the M11 is headphone output instead of line out output. Best regards
Dear friend, Thank you for the kind interest on our products. At about the middle of next month. Best regards
I believe the hd6xx is 300 ohms and the 660S 150 ohms. So yes, plenty of power to go by. 195mw at 32 ohms (22mw at 300 ohms) on the 3.5mm port. I say you need to be at 70 volume level and above to get good results. I suggest that you go balanced though for more power. Best to use the 4.4mm port. I believe it outputs 550mw at 32 ohms (88.5mw at 300 ohms). Hope this helps.
Thank you. Any plan to introduce an accessory like the DK1 dock for the M11 ? I would like to use M11 to replace my PC as transport / source into my desktop DAC / Amp setup!
