FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Discussion in 'Portable Source Gear' started by FiiO, Mar 19, 2019.
Tags:
211 212 213 214 215 216 217 218 219 220
222 223 224 225 226 227 228 229 230 231
  1. Sonic Defender Contributor
    waste of time, in my opinion.
    mattg3 likes this.
  2. harpo1
    I wouldn't say it's a waste of time. Try with and without and see which one you prefer. After all it all comes down to your sound preference.
    Jujoe and mattg3 like this.
  3. Jujoe
    This Dude knows whats going on :)
    Juj
  4. Sonic Defender Contributor
    Not trying to be defensive or dismissive, so I can't imagine there will be any appreciable benefit, the M11 is already a very well designed and engineered DAP with a very solid DAC and amplification section. I don't see a single thing about the D1 that suggests there is anything it could do better/differently. Maybe if it was intentionally coloured in sound character and the OP preferred the colouration, ok, for sure that is a possibility. So given that I think the choice of words of waste of time was poor, but the OP seemed to be asking for a straight forward evaluation and I again would suggest there is zero reason to think the D1 is going to add something besides colouration. That is my feeling anyway, nothing more, nothing less.
    CackalackyKen and mattg3 like this.
  5. harpo1
    He already owns it so why not try and see which one he prefers.
    Sonic Defender likes this.
  6. Sonic Defender Contributor
    Absolutely, never said otherwise, but the OP's own words were "would it be a waste of time", and in my opinion (just an opinion) it would be (most likely anyway). Would I test if I were him, sure, why not, you never know until you try.
    abitdeef likes this.
  7. abitdeef
    Well he did ask, and he was answered. I don't know why he just didn't try it if he was curious. But the other poster is right, it's going to take a really nice piece of kit to output a more 'quality' sound than the m11. Unless the OP finds the sound of m11 lacking?
    Me, I couldn't of stood it and I would have tried it immediately, unless I already heard it and knew there wouldn't be any improvements.
  8. mattg3
    The point of my inquiry rested on the fact that I own something I have not used in years but also Im not very understanding of a lot of the technical language about the M11. I have read here of people using separate amps with their M11 so I figured maybe Im missing something. Bottom line is the D1 would be a major chore to keep running with a wall outlet power source so going by Sonic defenders explanation Im going to put it behind me however I may just try it out when I have some time just to see what it can do. I have no issues with the M11 sound quality so Im not looking to correct anything. Thanks for your input.
  9. abitdeef
    Your ears don't need the tech info :wink: But it sounds as it would be a pita anyways.
  10. Sonic Defender Contributor
    Don't let me dissuade you from experimenting, could be fun, but yes there really should be no technical reason to expect anything. In some cases people may have headphones that require even more powerful amplification than the M11 provides, that is possible and in those cases makes perfect sense, or if the sound signature of a particular amp is deliberately coloured and they prefer the signature, those are great reasons. Always worth trying if you enjoy playing around. Cheers.
    mattg3 likes this.
  11. Jujoe
    Just remember "it's only kinky the first time"
    Juj
  12. cluelessears
    M11 seems to have a larger delay than the Hiby R3 when using it as a LDAC receiver causing videos to go out of sync with the audio. Can this be fixed?
  13. chechu21
    Can you give me the differences between Fiio M11 and X5 III?
  14. Jujoe
    I have tested with my phone to the M11 via bluetooth and I also notice a delay with Bluetooth sink mode.
    Juj
  15. abitdeef
    Too numerous to list specific differences and tech details can easily be found. But to sum it up m11 is better in every aspect, unless you like a warmer sound signature.
    Better dacs, better amps, better power management/better caps, better screen, better CPU, and better beer :wink:
