FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Discussion in 'Portable Source Gear' started by FiiO, Mar 19, 2019.
Tags:
210 211 212 213 214 215 216 217 218 219
221 222 223 224 225 226 227 228 229 230
  1. fatmanny
    You just made me realize there are more smilies than the Head-Fi ones......
  2. misteral201103
    Aurora is a fine store which will also help you to handle updates. Definitely my first choice for apps for the M11
    No, won't help you with UAPP. UAPP is not an option AT ALL without Google Account support, which will not come to the M11.
    superuser1 likes this.
  3. Currawong Contributor
    A lot of this has been covered in this thread at one stage (I actually got some ideas for the video from it) but here is review followup.
    xkoo likes this.
  4. Caguioa
    so like atleast 5+ have told me if my m11 is a zune
    ok but yea why does 846 I can control volume up and down.
    but fiio fh7 volume doesn't change on vlume adjutments.
    both are even using the same cable
  5. Currawong Contributor
    @Caguioa Swipe down from the top once so you can see the row of 6 icons. The third one should show a headphone icon. If it shows a circle with an arrow coming out, then you're in line-out mode. If it is, tap on it twice to get back to headphone mode.
  6. Jujoe
    Juj
  7. kailok18
    So FiiO any news on the Fiio Link function for FiiO Music on the iOS?
  8. FiiO
    Dear friend,
    You may check whether you have turned on the 'adjustable volume at LO' in settings-audio?
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  9. FiiO
    Dear friend,
    We will try to add this early next month.
    Best regards
  10. krumplib430
    Hi guys. Has someone already tried out airplay functionality of M11? As i heard airplay uses lossless compression for audio over wifi. Does this mean I can use any player on my Iphone, airplay it to M11 without any audio degradation? Is there any disadvantages?
  11. gLer
    It works well. To answer your question: yes and no. I believe Airplay is limited to 48khz (albeit lossless), though I could well be mistaken. Should be better than most Bluetooth codecs though.
    krumplib430 and Vitandus like this.
  12. abitdeef
    I also just ordered p1 and 2.5 connector (I think lol) ordered from linsoul as I didn't want to wait for mass drop. I like smaller iems and the price is really good for planar tech. - although it's 20 dollars cheaper at drop. Should go great with m11.
  13. Vitandus
    @gLer answered - confirming. I will put my iPhone into Hotspot mode when I'm out and use Apple Music that way It does sound better than BT out from my Android.
    krumplib430 likes this.
  14. Vitandus
    @Hawaiibadboy liked it in his initial listen. I enjoy the planar sound (I own iSine 20) and the FH7 delivers pretty close to planar quickness with the huge Be driver, but a cheaper set might be smart
  15. mattg3
    I have an old audio engine D1 24bit Dac /Heaphone amp with a USB in port and I haven't used it in years. Would it make any sense to plug my M11 using USB out to the D1 and plug my headphones into the Audio engine D1 3.5 input? Would this give me better sound or is this just a waste of time? Thanks
