FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Discussion in 'Portable Source Gear' started by FiiO, Mar 19, 2019.
Tags:
130 131 132 133 134 135 136 137 138 139
141 142 143 144 145 146 147 148 149 150
  1. Jujoe
    What are the chances of getting a pure music mode like the X5III, I never use any of the other stuff :)
    Juj
    Ojisan and gLer like this.
  2. gLer
    @JamesFiiO said they're considering adding this to the M11. Let's all make a big noise and show our support so it gets added soon...
    BadReligionPunk and Ojisan like this.
  3. gLer
    Let me know if you find one, I'd like one too. No matter how good the case, if the screen is exposed and unless you're using a UAG or other military-spec case, you're going to damage the dap if you drop it. A flip cover has saved my phone's screen dozens of times!
  4. mattg3
    ref=sr_1_35. Link for Amazon Screen protector for M11. If it doesn't work search for FiioM11 on amazon .You won't find the M11 but on page three you will find the screen protector.
  5. Jujoe
    To be fair even a full case like FiiO Q5 fiio m11 2.png I dont need to see whats going on just feel the buttons :)
    gLer likes this.
  6. gLer
    Haha, that’s exactly why I keep mine inside a case I stole from an old portable hard drive. As long as the volume and start/stop button are exposed I’m good 99% of the time. Still a made-for-M11 case like this would be cool - mine is only temporary (I’ll soon be keeping it in a FiiO hard shell case from AliExpress when traveling).
  7. Jujoe
    Oh dang nice sleeping bag, hard case off ali you say I'll have a look thanks.
    Juj
    gLer likes this.
  8. jmills8
    All this fuss about covering your dap with fabric or leather. I never used a case and I use them always on the go. Zero scratches cause the dap goes in my pocket.
    ExpatinJapan likes this.
  9. gLer
    Jujoe likes this.
  10. gLer
    Didn’t you drop and ding your N8? Or am I confusing you for someone else? :wink:
  11. fatmanny
    WIN_20190605_09_58_42_Pro.jpg WIN_20190605_09_59_42_Pro.jpg WIN_20190605_10_00_04_Pro.jpg This is my first setup that actually takes music quality into consideration. I made the decision to ditch my smart phone and, instead, get an old Blackberry and this monster to fill the void that I had for music. While my IEMs aren't the greatest, I'm happy with what I have...for now :beyersmile:
  12. Jujoe
    Think your cables are going to wrong ear tips
    Red to red white to blue
    Juj
  13. fatmanny
    That's how I initially had them set up, but the channels were backwards. So I matched the colors as I have them now and things are working better.
    Jujoe likes this.
  14. jmills8
    Correct and that was due to the case. First time I used a case since 2006. First week and the N8 slide out of the leather case fell 12 ft onto the sidewalk and slit 10 ft. Now no case and no issues.
  15. se7en7
    Just got the M11 loaded up Spotify APK via APKpure.
    It's quite slow to download music via 5ghz and the actual navigation is slow could this be down to micro SD storage I have selected or anything else?
    The screen hangs whilst trying to select a song.
    Thank you
