FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Discussion in 'Portable Source Gear' started by FiiO, Mar 19, 2019.
Tags:
111 112 113 114 115 116 117 118 119 120
122 123 124 125 126 127 128 129 130 131
  1. dissembled
    Thanks, I see it now.
    One has to select Fiio M11 high resolution on the search prompt and it appears. Or alternately, search for the M9 and select M11 in the product page itself, as you suggested.
  2. Vitandus
    I can hear it on soft tracks - background ain't black to me. I bought the IEMatch from iFi and ahhhh sounds good.
  3. aaf evo
    Yeah I agree it definitely has some hiss but it’s far from a deal breaker.
  4. BadReligionPunk
    Well, I have iPod Mini, iPod 5.5, Sony Nw-A45, Cayin N5. Axon 7m, And some cheappy Chinese Mahdi Dap. The Cayin N5 is by far the best dap I had, and was used the most. Mids forward Dap with good "energy". Received my M11 yesterday, and am blown away. Like its very noticeably better then N5. Still loading music and figuring this thing out but wow. Layering and stage is so good. Its also smoother then N5 and cant tell if there is any stand out frequencies. seems really balanced.
    LOve It!
    superuser1, CactoesGel and abitdeef like this.
  5. MariusAB
    What iems, headphones you are using? so hearing this difference. Wondering what "level" of iems are needed to open all potential of m11. By the way, happy to hear one more happy m11 owner :) this shows how good m11 is
  6. abitdeef
    Coming primary from ak sr15 as what I had been using the most prior to m11 it is an 'eye opener' in every way compared to the ak. The bigger soundstage, more 3d like presentation hit me first. Sr15 stage isn't as big, bigger than m6 but not like m11.
    Same way the dx220 stage hit me, and similar to the wm1a stage- very impressive at the price. I was thinking the dx220 might have more bass presence but honestly it was hard to tell. Since I initially received it it sounds a bit more refined and not as 'rough' sounding. I like that raw energy sometimes. :)
    aff evo should be able to tell more with the more complex/revealing iems he's using.
    But the UI speed and smoothness, well I don't think I could ever go back to other daps. Unless they sounded substantially better and weren't crazily priced.
    Fiio has a nice dap here for a good value and I hope the next 2 follow the same trend.
  7. BadReligionPunk
    Just using $50 chifi(BQEYZ KC2) and $20 DT6. Both are pretty balanced and both have pretty good detail retrieval. But yea, so far have not even broken out the more expensive stuff.
    Did spend some time this morning on the same songs, going back and forth between m11 and N5, and the difference was very noticeable. Cayin is more closed in and congested sounding. Also more mids forward, not as smooth. I LOVE my Cayin, but this thing is on a different level. I believe hawaiibadboy when he compares it to more expensive daps.
  8. shadow84
    Just bit the bullet for m11 as i find it to have a slightly wider soundstage, bass presence and deeper from my opus #1.
    Would a 4.4mm balanced sound different from a 2 5mm balanced? Cureently using 2.5mm balanced toxic - Virus cable. Also, can i install hiby music via the apkpure app?
    Lastly, any links for a better case like leather type? The plastic one seems fine to the touch for me but i dun mind a nicer case. Lol
  9. BadReligionPunk
    2.5 and 4.4 should be identical. Its just a more robust connection. 4.4 is just a beefy big jack. I have breathed on 2.5's and broken them. Very weak IMO.
    dsrk likes this.
  10. abitdeef
    Hiby music works great, and here is a link for leather case, its also on Ali Express. Might order it myself, 25 dollars isn't bad for a real leather case. I usually pay 90 to 100 for Sony or ak cases. The tpu is functional but the dap has that high end feel :wink:
    https://penonaudio.com/fiio-sk-m11.html
  11. exitfire401
    Just a heads up, the case is synthetic leather. Still a nice case, but want to make sure you're aware before ordering.
  12. abitdeef
    Wow that's really misleading then. I even think there's more info on the Ali Express page that makes it sound like soft natural supple leather.
    Not that it matters much, my 90 dollar case for my ak sr15 wasn't leather but you knew that from the description. I don't think you should be able to call any synthetic case 'leather'.
    How's the fit? I like a bit tighter low profile fit myself.
  13. pnzr
    @FiiO please make the search function of FiiO Music available on all screens. there's enough room to work with to have the little loop everywhere.
    also does anyone have any experience with a case from the easecase seller on aliexpress? They have a customisable case for the M11 up on there which looks really nice.
  14. exitfire401
    Fit is fantastic. Grips the player well and I don't have a problem pushing it out if needed. It won't slip out by any means. It's no lower profile than the TPU case and honestly probably a little less protective as it doesn't cover all sides like the TPU case. Personally, I really like it and was really happy with my purchase. As long as the material holds up over the next year until I can have a friend make me a case, it will have been well worth $25.
    abitdeef likes this.
  15. kdphan
    Not seeing the M11 available on Amazon :frowning2:
