FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Discussion in 'Portable Source Gear' started by FiiO, Mar 19, 2019.
Tags:
107 108 109 110 111 112 113 114 115 116
118 119 120 121 122 123 124 125 126 127
  1. Leetransform25
    I don't own an M11 so I'm not 100% sure but I'd assume audio will only play through one jack at a time.
    radarnigz5 likes this.
  2. Leetransform25
    Lmao that song's amazing
    abitdeef likes this.
  3. abitdeef
    The albums a classic and the MFSL version really sounds amazing!
    Leetransform25 likes this.
  4. abitdeef
    I'm afraid to try both at once lol, but I'm sure only one works at a time so I would say a splitter is the way to go.
  5. radarnigz5
    what will happen if i put multiple jacks to try, is it gonna smoke?
  6. radarnigz5
    splitter it is :)
  7. Leetransform25
    I doubt anything bad will happen, all that'll probably happen is that audio will only come out of one pair and not the other
  8. jmills8
    Buy two daps.
  9. abitdeef
    Solid advice!
  10. aaf evo
    Just got the email that my M11 from Amazon shipped, arriving tomorrow! :)
    BadReligionPunk likes this.
  11. Currawong Contributor
    For people who hadn't noticed, open the "Applications" app. In there are the most common apps. The rest can be found easily by installing APKPure from the Applications, then using that to find other apps.
    If you're using it at a desk, just leave a USB charger plugged in and the battery should be fine.
    Use the sharp filter if you mainly listen to acoustic, or like a more accurate, precise sound, or are an objectivist and want the best measuring output. Use the slower filters if you want the sound a bit softer, or listen to a lot of electronic with unnaturally sharp transients and sounds. Or just play with the options and see what feels best to you.
    This is the Head-Fi way! :wink:
  12. abitdeef
    Very cool, can't wait to hear what you think!
  13. JamesFiiO Contributor
    The current output may be too hight so the M11 may active the protect function and the output will be disable.
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  14. BadReligionPunk
    Me too. Mine just coincidently left Houston an hour ago. Will have it tomorrow.
  15. abitdeef
    Two more joining the club :)
