[FIIO KA5/KA15]FiiO Portable DAC and Headphone Amplifier
Sep 17, 2024 at 9:09 PM Post #572 of 997
Compellingly Fun
An Outstanding Display
The KA15 uses a 0.96-inch IPS true color LCD screen among similar dongles and supports both Chinese and English language display. The settings menus have been designed to be more intuitive and user-friendly. Additionally, the KA15 features a new retro dynamic UI, combining technological innovation with classic design. With the simulating spinning tape, you can truly feel the uniqueness of the KA15.
There is 1 day left before the launch of the DAC and Headphone Amplifier KA15. Let’s stay tuned!
Sep 17, 2024 at 9:25 PM Post #573 of 997
Compellingly Fun
01001111 01101000 00100000 01000110 01110010 01100001 01100010 01101010 01101111 01110101 01110011 00100000 01000100 01100001 01111001 00101100 00100000 01000011 01100001 01101100 01101111 01101111 01101000 00100001 00100000 00100000 01000011 01100001 01101100 01101100 01100001 01111001 00100001 00100000 01010011 01101111 00100000 01101000 01101111 01110111 00100000 01101101 01110101 01100011 01101000 00100000 01110011 01101000 01100001 01101100 01101100 00100000 01101001 01110100 00100000 01100010 01100101 00101100 00100000 01001001 00100000 01110011 01100001 01111001 00111111
00001010 00001010 00001010 01001111 01010010 01010100
:beerchug:
Sep 18, 2024 at 2:46 AM Post #574 of 997
:beerchug:
You miss an one in the third line...
Sep 18, 2024 at 4:45 AM Post #575 of 997
@FiiO Kang
I notice KA15 doesn't have a "power in" usb port like KA17. Does this mean that when connected to a phone it is able to give me 560mW of power in desktop mode?
If so, how fast will my phone battery drain I wonder?
With KA17 this issue is solved with a power bank that I have from Anker.
KA15 at normal listening volume. Current consumption is about 140mA.
1. in order to be smaller, the KA15 does not design a "power in" usb port, but you can achieve the function of separate power supply through some "dual port cable".
2.KA15 can greatly reduce power consumption when pausing or stopping music. This saves electricity. It can also be convenient for some people to set a timed playback while sleeping, and avoid running out of battery the next day
Sep 18, 2024 at 7:21 AM Post #576 of 997
Tune the sound when you are free. This is the fun brought by the PEQ function of #Interesting Listening Dongle DAC, FiiO KA15#. We can adjust a sound more suitable for ourselves according to our own preferences, for different headphones, for different music styles, and even for different moods.
Sep 18, 2024 at 9:18 PM Post #578 of 997
:beerchug:
01001001 01110100 00100111 01110011 00100000 01100010 01100101 01100001 01110101 01110100 01101001 01100110 01110101 01101100 00101110 00100000 01001001 01110100 00100111 01110011 00100000 01100101 01111000 01100011 01100101 01101100 01101100 01100101 01101110 01110100 00101110 00100000 01000001 01101110 01100100 00100000 01101001 01110100 00100111 01110011 00100000 01101110 01101111 01110100 00100000 01100101 01111000 01110000 01100101 01101110 01110011 01101001 01110110 01100101
Sep 18, 2024 at 10:46 PM Post #579 of 997
Releasing today?
Sep 19, 2024 at 3:50 AM Post #581 of 997
DAC and Headphone Amplifier KA15 Is Officially Released!​
The KA15 has been completely revamped inside and out. It combines FIIO’s experienced audio know-how on the inside with elements of retro tape recorder looks on the outside.
The new generation of FIIO’s 5-series audio dongles inspires endless fun with avant-garde innovation and appeals to quality enthusiasts with a practical design. It brings together great sound, ergonomics, fun, and aesthetics, all into a single tiny and convenient package!
Limitless enjoyment, be your own music tuner
The audiophile-grade DSP allows the KA15 to feature a ten-band high-precision lossless PEQ, which operates smoothly and with high quality thanks to FIIO’s self-developed advanced adjustment algorithms.
Through the control app or the web interface*, not only can you simulate or correct the frequency response curve of headphones but you can also export, import, share, and save EQ curves. Whether you choose to use officially recommended tunings or choose to share your tunings online with other enthusiasts, you can easily enjoy setting up EQ the way you want it.
*Access to the web version of PEQ: Top status bar at fiio.com ->Support ->Web-based PEQ settings.
Intelligently fun, intelligent dynamic power consumption
Equipped with a high-performance, low-power processor and high-precision chips, the KA15 innovatively features real-time voltage and current monitoring for dynamic power adjustment. By recognizing the device’s playback status, it intelligently adjusts the overall power consumption, allowing your phone to run using less power. When you set a timer for music playback during the night, once the timer ends the KA15 will enter an ultra-low power sleep mode - so you don’t have to worry about your phone’s battery being low when you wake up the next day.
Compellingly fun, an outstanding display
The KA15 is the first to use a 0.96-inch IPS true color LCD screen among similar dongles and supports both Chinese and English language display. The settings menus have been designed to be more intuitive and user-friendly. Additionally, the KA15 features a new retro dynamic UI, combining technological innovation with classic design. With the simulating spinning tape, you can truly feel the uniqueness of the KA15.
There are more impressive functions- powerful 560mW+560mW desktop mode, dual CS43198 + dual op-amps, supports 768kHz/32bit and DSD256, app control, 60-step quick adjustment and 120-step fine adjustment available, supports microphones, 3.5mm jack supports the CTIA standard of in-line controls, supports connection with the Switch, PS5 and other devices under UAC1.0 mode... Check on the product page for more details.
* The KA15 is available on our AliExpress Official Store. Click the link to take it home right away: aliexpress.com/item/3256807569410597.html
Best regards,
Guangzhou FIIO Electronics Technology Co., Ltd.
Sep 19, 2024 at 4:11 AM Post #582 of 997
Sep 19, 2024 at 11:01 AM Post #583 of 997
Kudos to FiiO for offering all the functionality we need in a dongle, and real buttons :L3000:, and at a great price.
Sep 19, 2024 at 11:49 AM Post #584 of 997
Of course they are not the same thing - where did I say they were the same ?
Advertising filters is nice but does not impact SQ anywhere near as much as EQ.
And who is asking for KA5 to do PEQ?
Did you read what I wrote after FiiO already replied ?
I wrote: "Ok - we need more products with parametric EQ built-in"
This is clearly not in reference to KA5....
Equalizers were very popular in the 1970's but gradually fell out of favor by the 1980's. Since headphone listening has become far more mainstream over the past decade, equalizers are starting to experience a Renaissance. When one considers how much some headphone enthusiasts spend on modifying their headphones, it just makes sense to own a graphic equalizer, which can be used to tailor the sound of your headphones without going to the trouble or expense of having your headphones modified. This is especially true if you own several headphones. And you don't have to spend a fortune on a graphic equalizer. I have been using a Schiit Lokius for the past few years and find it very useful in fine tuning my headphones. Of course there will always be those DIY enthusiasts who want to experiment by modifying their headphones, and this DIY experimentation can be enjoyable and also serve to make useful discoveries in extracting the most sonic benefits from a headphone. 👍
Sep 19, 2024 at 1:08 PM Post #585 of 997
Low consumption seems great. A real game changer ... I would love to compare it to your other devices especially the kA5.
I would like to see a table or set of charts comparing all of Fiio's DAC offerings instead of my having to look all over the internet to make my own table. Their posts here only seem to compare superficially to the KA5 but what if you have another one like the "lowly" KA1? You can't just say it's better. Would like some data to cross-reference easily.
