FiiO K9 Pro Hi-Fi DeskDop DAC&Bluetooth&Amplifier,XLR/RCA/4.4/Optical/Coaxial interface
Jan 12, 2022 at 6:37 PM Post #1,006 of 2,219
@Vitaliy Belz I've been thinking about it for a long time myself. Especially if you put it on its side. In a good way, you need to measure the temperature of individual nodes and see their technical characteristics. I wouldn't be surprised if everything is within operating temperatures. It's just now such an element base, large currents. Warm air has become the norm.
Jan 12, 2022 at 7:32 PM Post #1,007 of 2,219
Hmmm.......would be interested to know what you all think of this - I've always run my HEDDphones on high gain, but just now I thought I'd try them on medium. Obviously, I've had to turn the volume up more, but the dynamics seem to be improved, somehow the balance of the sound between low, mid and high frequencies seems better and I'm pretty sure that the sound stage and separation is improved. Let me know what you think - but maybe you'll need power-hungry headphones to hear the difference.......?
Jan 12, 2022 at 7:42 PM Post #1,008 of 2,219
@looki look I myself do not like low-quality resampling with bad fast algorithms. Android is Linux. On Linux, resampling is handled by the sound server, depending on its settings or restrictions imposed on it by the receiver. We believe that the music player does not change anything. The receiver is a BT transmitter module. Conclusion: You need to delve into the settings of the Android sound server and the BT transmitter. But is it worth the bother? I doubt that you will hear the difference between 44.1 and 48 in BT mode.
Jan 13, 2022 at 10:01 AM Post #1,010 of 2,219
The way to reproduce the issue is as below.
1. Move the first switch all the way down apply bit more pressure to move the switch down.
2. Move the gain to high gain as it only reproduce in high gain. When switching to other gain its working fine.
3. Play some music, wait for few sec 10 or 20 sec the audio output switches from HP to DAC mode (the volume slider was not changing the volume on my xb30 speaker.
Attached a video link where the sound was first played in sundara and then in fee sec it auto changes to DAC mode with some internal clicks in K9 pro.
https://drive.google.com/file/d/1Ok47VIivoarY99wN5PyZH10OZZpU11RT/view?usp=drivesdk
If any one else is facing the same issue then they can use below drivers for K9 pro:
https://drive.google.com/drive/folders/1SbHauynXIqGQH93BL5pJMi5b0cXlZT8_?usp=sharing
This driver change the timing of the mode change by 1 sec or 2 which lets K9 Pro smoothly transition to other mode and doest bounce back to other mode on high gain.
This delay is bearable and definitely resolved my issue.
I was really amazed the fast response and fix I got from fiio support. Thanks.
Jan 13, 2022 at 2:33 PM Post #1,011 of 2,219
If you get a benefit, then great.
(A couple of my headphones respond to that approach quite well too, not just a K9pro thing IMHO).
Jan 13, 2022 at 7:37 PM Post #1,012 of 2,219
Yes, there is a 2 second delay when switching the gain button. :L3000:
Jan 14, 2022 at 1:35 AM Post #1,013 of 2,219
Will this plastic shield lead to rapid degradation of electronic components?
Dear friend,
1. This plastic shield could keep the structure more stable. The K9Pro would not be damaged by the plastic shield under normal usage.
2. Though the radiating will be affected slightly, the K9Pro has temperature detecting and protection which could keep the K9Pro work in safe range. So please don't worry.
Best regards
Jan 14, 2022 at 5:44 PM Post #1,015 of 2,219
The main task of the screen is to "keep the structure more stable"! I realized that this gives additional rigidity to the circuit board. I didn't understand anything from the rest of the explanation. If this is interesting, then measurements of the temperature of the nodes are needed... after 1 hour.. If someone is still not sure about this plastic screen.... It doesn't bother me. I'm interested in something else. Are the internal generators in the BT module de-energized or not? When manually switching the sound source, for example to USB or COAX. Are there knowledgeable?
Jan 15, 2022 at 5:40 AM Post #1,017 of 2,219
you can adjust volume with app through BT in all modes (tried with coax) so BT module can not be de-energized without loosing App-control.
has anyone win11 and tried BT to k9pro? I just installed a new Win11 with a intel ax210 bt 5 card. But I can't see fiio k9pro. Is this not possible with Win11/only possible with Android?
I see with win11 much less devices than with android, so I suspect the win11 bt driver...
Jan 15, 2022 at 7:04 AM Post #1,018 of 2,219
@looki look Thanks! Helpful information. With an infrared remote control, life would be easier. Well, or with an additional option to turn off the power of the BT module in the control program for the "USB, COAX, OPT, LINE" mode. And more about Android. The resampling rate can be changed by another program running at the same time as the software player. The sound server has given this program priority. It could even be an antivirus.
