[FiiO K5Pro/K5Pro ESS]Desktop DAC and Amplifier+768K/32Bit and DSD512 decoding+3 gain levels
Aug 16, 2022 at 3:08 AM Post #586 of 609
FiiO
Sponsor: FiiO
Guangzhou,China
I don't have a multimeter but the adapter works fine. I've tested it by using the K5 Pro adapter on a Philips lamp and the lamp powers up.
Using the adapter of the lamp does not power up the K5 Pro so it is the probably the K5 Pro itself that is broken.
Dear friend,
Sorry to hear about that. According to the phenomenon you metioned, I am afraid that it may be a hardware issue with the K5Pro as well. You could try to contact the seller for help first. If the seller fails to help, please contact support@fiio.com with the receipt attached.
Best regards
Aug 16, 2022 at 11:11 PM Post #587 of 609
FiiO
Sponsor: FiiO
Guangzhou,China
Super Stable! FiiO Low Noise Regulated Linear Power Supply PL50 Is Available on AliExpress Official Store!
Power supply is always a significant factor that affects the audio system. Among them, linear power supply is born with low noise, small ripple and stable voltage output. The FiiO's low noise regulated linear power supply PL50 is not only a synthesizer of these merits, but also comes with other outstanding features.
For one thing, we specially customized a 50VA audiophile-grade toroidal transformer, made of high-quality Nippon Steel iron and high-purity oxygen-free copper wires for higher efficiency, higher precision, more stable voltage, and for higher energy output.
For another, high-quality parts were chosen for every part of the design for higher and more reliable performance – such as the Shindengen bridge rectifier, TI voltage regulator, and Nippon Chemi-Con and Rubycon capacitors.
What's more, the PL50 has been designed and manufactured according to strict safety standards. With high-standard crafting, the PL50 is exactly an excellent power supply to help create a pleasant music experience.
Keep features of the PL50 include:
--Low noise
--High precision
--High power
--Stable voltage
* The PL50 is available on our AliExpress Official Store. Click the link below to take it home right away.
Click here
Best regards,
Guangzhou FiiO Electronics Technology Co., Ltd.
Aug 16, 2022 at 11:22 PM Post #589 of 609
nodle
The Twilight Zone
That power supply looks great and all but that price tag is almost as much as the K5pro itself. I would be all over it if it was about half that. It does looks great though. Honestly though I don’t know how cleaner they sound of the K5pro can’t get though, that thing is dead silent.
Aug 18, 2022 at 11:55 PM Post #590 of 609
FiiO
Sponsor: FiiO
Guangzhou,China
Dear friend,
Thanks for the kind feedback.
Best regards
Aug 29, 2022 at 10:15 AM Post #592 of 609
Umwelt
United States
These Desktop amps/DACs seem to do it all well, very interested! Just wondering about the line in input for some retro game sources.
Does the analogue line in input on the K9/K5 Pro ESS go through digitization and then back to analogue for the phones output, like other amps do? If so is there any delay due to the sampling rate used for the conversion?
Or rather is line in to phones out a straight analogue path?
Aug 30, 2022 at 10:17 PM Post #593 of 609
FiiO
Sponsor: FiiO
Guangzhou,China
Dear friend,
If you are using line in and headphone out in K5Pro, it will not go through the digital module. The K5Pro is working as amplifier at that time.
Best regards
Sep 28, 2022 at 12:53 PM Post #595 of 609
ahmonge
Spain
Sep 28, 2022 at 3:44 PM Post #597 of 609
ahmonge
Spain
@FiiO what’s the optical max data throughput for data
32/192 or 24/192 kHz
Or is it less than this and only on usb input only ?
Thank you
According to Fiio specs:
768kHz-32bit/DSD512(USB DAC)
192kHz-24bit(COAX)
96KHz-24bit(OPT)
Sep 28, 2022 at 3:57 PM Post #599 of 609
se7en7
192kHz-24bit(COAX)
96KHz-24bit(OPT)
thank you for the information much appreciated
A couple more to you @ahmonge
I notice you have Qobuz does the optical input allow for full lossless as i am potentially going to hook a wiim mini which allows Quboz and Amazon Music ultra hd bit rate files.
Also if i have Sundara was thinking of Edition XS or Ananda
I listen to lots of different music genres but mainly rock, Progressive etc.
Would you recommend the Ananda for that genre of music thank you
Sep 28, 2022 at 5:43 PM Post #600 of 609
ahmonge
Spain
I only use the optical input to connect the TV, Qobuz I listen to it from the PC or mobile phone via USB. Because of the 96 kHz limitation of the optical input, you will not be able to listen to Qobuz tracks encoded at 192 kHz.
Ananda is an improvement over Sundara in the timbre of acoustic instruments in classical music, especially strings; for that reason I chose these headphones over the Sundara, as that is the genre I listen to most, but I don't dislike them at all when listening to other styles of music, such as Jazz, classic rock, country or Americana, although the Ananda are a bit bright in the treble for these styles. If you can, give them a listen before deciding.
