FiiO K5 || FiiO's docking desktop amp
post-12430394
Post #511 of 732
kdub
I tested it this week with 3 different tube amps. No interference, hum or noise whatsoever :blush:
How did you set it up exactly to the tube amp from K5? RCA out from K5 (thought these were just for pre- amp purposes) to RCA input on tube amp?
post-12431242
Post #512 of 732
Ultrainferno
Member of the Trade: Headfonia
Website
www.headfonia.com
That is exactly how
post-12432284
Post #513 of 732
kdub
post-12436265
Post #514 of 732
Shetzu
Tropical
Tropical
Today a strange thing happpened. Suddenly while  plugging the K5 to the supplied power adapter it started making strange sound of clicking. Like some relay sound from inside like a clock. When I turned the Volume knob switch to ON mode the red light flashes in ressonance with the clicking sound coming from inside and does not power ON.
I  have sent a mail to distributor Origin Games for exchange/refund.
post-12436287
Post #515 of 732
CH23
tried unplugging the unit and power adapter?
post-12436293
Post #516 of 732
Shetzu
Tropical
Tropical
Yes I unplugged it and tried plugging it again but the same issue is there
post-12436704
Post #517 of 732
CH23
post-12438429
Post #518 of 732
Shetzu
Tropical
Tropical
definitely broken then...
Yeah. I have sent a mail for exchange/refund to distributor. Hoping to hear from them today.
post-12438642
Post #519 of 732
t258jgn
Doesn't it also do the X5SG on balanced? Haven't tried though
EDIT: For better signal transmission: connect the X5II/X7 to the K5 through its docking connector, then output via the double3.5mm Balanced Line out port at the back of the K5 to a desktop amplifier/headphone amplifier that has an XLR input port.
On Fiio K5 product page indicate X5 II can also be used for Balanced Out.
But mine cannot.
Why?
post-12438754
Post #521 of 732
Joe Bloggs
Member of the Trade: HiBy / EFO technologies Co
His Porta Corda walked the Green Mile
Hi kdub, here is the image for your reference :
Can anyone show me the pin-out for the Balanced Cable?
I have asked someone to custom make the cable but when I use with X5 Gen2, no sound comes out from my Amp
The cable is made using
Belden Star Quad 1804A Cable BLACK(2 Mtr) + Neutrik NC3MXX-B Gold XLR Male + Lumberg 3.5mm 4 Pole Male Connnector
Sorry for the late reply.
Well this doesn't sound right. The balanced output of the K5 is 6 poles spread over two connectors (left port: left channel +, left channel -, ground; right port: right channel +, right channel -, ground). It sounds like you're trying to adapt this to an amp accepting four pole input (left channel +, left channel -, right channel +, right channel - only).
Please consult the manual of your amp for the full pinout of your XLR input(s). Meanwhile here is the pinout of the K5's balanced outputs:
Two ports for 3 pole 3.5mm male connector.
For left channel male connector:
Tip: left +
Ring: left -
Sleeve: ground
For right channel male connector:
Tip: right +
Right: right -
Sleeve: ground
Please present this complete specification for the K5 together with that for your amp to your DIY builder to build the appropriate adapter cable, thanks.
Best regards,
Joe
post-12457909
Post #522 of 732
Ab10
IND
IND
I strongly doubt -  this is the issue which generate only when the adopter (power brick) provisioned for 3 Pole but the supplied AC Plug only have 2 pole. Actually the supplied one indeed 3 pin but only usable when user situated at France - Not India.
Please post any update or difficulty about replacing the product....So we can learn.
post-12458057
Post #523 of 732
Shetzu
Tropical
Tropical
I sent the unit back to distributor who tried it and had no issues. Finally I came to the conclusion it has got nothing to do with 3 pin plug adapter or 2 pin plug adapter. Apparently I had plugged the unit to multi socket Belkin Extension chord which has spike control. Si I feel their may have been spike in electricity which may have caused this issue.
THe distributor used my unit under watch for 3 days and found no problems. Today he is sending it back to me.
post-12458071
Post #524 of 732
Ab10
IND
IND
Thanks for the update.
Glad To know the fact and actually relieved - I'm also using the Belkin Spike Strip - Hope I may not face the same issue.
Though I insert flat metal sheet which goes to directly to Ground Pin hole of the Belkin Strip and the rest in the contact of the French Ground pole area....better than nothing...I presume.
post-12458096
Post #525 of 732
FiiO
Sponsor: FiiO
Guangzhou,China
Guangzhou,China
Age
12
Website
www.fiio.com
