- Oct 6, 2013
If you want android support (using UAPP or Hiby type of apps that utilize their own usb drivers) - yes for Q1. I didn't get a chance to a/b in my review since I was focusing more on other "thumb-drive" footprint usb-dacs for comparison, but they should be on par... Actually, just did a quick K1 vs Q1 comparison and K1 has a little more sparkle and wider soundstage while Q1 is smother and low end extends a little deeper. But overall similar.
My Nexus 6p is plug and play working with any application on either the Fiio Q1 or HRT MicroStreamer. The 6p has USB C and connects using a straight USB cable, not OTG. It also runs Android Marshmallow OS.
These are the portable DACs I have but it seems like this phone would work with anything.
Perhaps they changed something in Android 6.x, Google has been promising native usb dac support for awhile now. I'm on Note 4 with a stock 5.x Lollipop, so no luck. Are you using usb-c to micro-usb cable connected directly? Astrapi, dSp, HA-2, etc. all come with micro-usb to micro-usb cables that look "normal" but actually have Pin 4+5 shorted internally to enable usb otg.
