[FiiO FH7] Flagship 5-Driver (1DD + 4BAs) Hybrid In-Ear Monitors, Knowles DFK + SWFK Composite BA Drivers, 13.6mm Beryllium DD Driver
Aug 31, 2019 at 1:58 AM Post #1,171 of 1,922
also how do you disconnect the original cable anyway? dont want to break anything
That is the wrong cable yes. I can't comment on whether or not Amazon sent you the wrong cable though, you may have ordered the wrong cable.
To disconnect an MMCX plug simply hold the connector firmly, not the wire and pull it straight out, it may take a bit of force to disconnect.
Aug 31, 2019 at 9:49 AM Post #1,173 of 1,922
i TRIPLE checked they sent wrong cable EVERY picture they showed, showed the connector for the FH5 then that showed up
Aug 31, 2019 at 10:12 AM Post #1,176 of 1,922
Aug 31, 2019 at 11:54 AM Post #1,178 of 1,922
https://www.amazon.com/gp/product/B07GGZCFD2/ref=ppx_yo_dt_b_asin_title_o01_s01?ie=UTF8&psc=1 lists FH5 as one of models supported and pic shows the connector the FH5 uses, talked to Amazon they are sendiing me a new item and return label
Sorry for your trouble but I appreciate you posting the link. I see that the lc-2.5d is back in stock, which I've been waiting for.
ETA: BTW be careful with the MMCX connectors. I returned the lc-2.5C due to a very unstable fit. It may have been just the ones I received but just a heads up.
Also, I had a bit of trouble removing the stock cable. It's very tight so make sure you grip it as close to the pins as possible and pull straight out.
Aug 31, 2019 at 3:37 PM Post #1,179 of 1,922
i managed to get the stock ones out ya tight fit
Aug 31, 2019 at 6:17 PM Post #1,180 of 1,922
Hi guys can someone please tell me where i can the exact same double flange tips coming with the FH7 as a spare?
I appreciate any help
Sep 2, 2019 at 1:26 PM Post #1,181 of 1,922
Gentlemen, anyone versed in Chinese that can translate? Looks like a wireless BT adapter for the FH7...
Sep 2, 2019 at 1:40 PM Post #1,182 of 1,922
hifi really wireless?
Inrtoduction of the ITR cable?
Enthusiastic for wireless?
3 frequency wireless ?
I am proud of exploring HIFI infinite possibilites
All via google translate :)
Sep 3, 2019 at 3:49 AM Post #1,184 of 1,922
this is a TWS receiver with MMCX connector, so you can change our FA1/FA7/F9/F9PRO/FH1/FH5/FH7 to a TWS IEM.
