I may switch back to the balanced or bass filters because while vibrant I think the treble filters might just be too vibrant with the Spirals. Also Dekoni Bulletz have far more isolation than the Spirals, but that’s always been the case. So for flying or tubing, foams are the only way (and they seal even better with the o-ring mod).My large Spiral Dots arrived yesterday and loving them for superior fit and isolation they give compared to the spinfits. Slightly different sound to spinfits and not sure which I prefer yet. Could be spinfits are slightly more vibrant and exciting sounding altho I use them with the bass filter for optimum results with my ears. Black filters with the Spirals work better than on the spinfits altho I've reverted to bass filter for the moment nonetheless.
[FiiO FH7] Flagship 5-Driver (1DD + 4BAs) Hybrid In-Ear Monitors, Knowles DFK + SWFK Composite BA Drivers, 13.6mm Beryllium DD Driver
Jujoe
Cool what are the dekoni size bore is it you use?
MrJudasPriest
How does the o ring mod work for spirals? Are they easy to acquire and idiot proof to install? If yes to both, may have to investigate further...
https://www.amazon.co.uk/Dekoni-Audio-Moldable-Isolation-Earphone-Black/dp/B01M0SGE1SCool what are the dekoni size bore is it you use?
Jujoe
You just slide the o-ring over the nozzle, push it flush with the earpiece, and then fit the Spiral tip as usual. Pushes it 0.8mm to 1mm forward, depending on the thickness of the o-ring. You don’t want to get an o-ring thicker than 1mm.How does the o ring mod work for spirals? Are they easy to acquire and idiot proof to install? If yes to both, may have to investigate further...
Search a few posts back where @Jujoe pointed to an o-ring you can use.
Jujoe
Thanks dude might grab me a set for the hospital days
For those not in the uk they are called - Dekoni Audio Mercury Premium Foam Eartips 4.9mm
With the o-ring mod I use the S size instead of my regular M size.Thanks dude might grab me a set for the hospital days
Jujoe
OK I might get a multi size pack thats great info buddy thanks
Are the large or even the medium bigger than the FH7 foam tips? as no amount o rings will get them to fit me lol
MrJudasPriest
I used the o-rings left over from dampening my keyboard.
https://www.amazon.co.uk/gp/product/B00UFLH7FK/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Thanks for the tip (no pun intended) - just ordered a few of the rings that you linked.
Jujoe
They are also great to use on a cherry mx keyboard to stop bottoming out noise heavy typer
Jujoe
Excess? You mean ear wax?Has any one got any iedas for getting rid of the excess round the center of slicon tips
Ah, that’s just the seam. Par for the course in silicone tips.LOL no this little ring on the tip
Total: 6 (members: 0, guests: 6)
