JaZZ
I did exactly this comparison this even during my 2-hour relaxation on the balcony, with FiiO X5 II, Hugo M Scaler, Hugo₂ and a Science-Fiction book in front of me on the table.Sorry for my english but I use a translator. I'm thinking about buying andromed or fiio fh7. Could someone write what would be a better choice or write a comparison? Thank you.
If you want the FH7 because you like what you read on this thread, you're on the right track. It's a highly musical IEM with a pleasing if not even spectacular sound, despite the relatively neutral tonal balance.
Now the problem with my comparison is that I never listen to my earphones with their factory settings, I always try to equalize them to what I perceive as a neutral sound with good extension to both frequency extremes. So keep that in mind.
Particularly since the Andromeda needs quite a bit stronger corrections than the FH7, but compensates for that in the form of an ultra-clean sound with horrendous transient speed. The upper treble is slighty emphasized, a strong contrast to the FH7's drop-off there. However, both flaws can be satisfyingly fixed via the X5 II's equalizer. Better than the slight low-bass deficit with the Andromeda. That said, if the FiiO players' equalizer would allow for more than +/– 6 dB or provide one more EQ band below 31 Hz, it would be possible to bring the low bass to the level of the FH7 – and maybe a comparable «musicality» and «muscularity». BTW, the Atlas is a strong contender for the FH7 as well, particularly in this aspect.
Here's a comparison of the used compensation curves to give you an impression of the tonal balances with the respective «factory settings» (according to my subjective perception):
Considering the price I would consider the FH7 the most interesting option, particularly due to its outstanding musicality. The Andromeda on the other hand has outstanding «technical» qualities that may even exceed the FH7's level, but it's more of an intellectual than a sensual delight (although of course it's nevertheless highly musical as well). The Atlas may be something in between the two, with a bass similar to the FH7 – in both quality and extension – and an impuslivity even slightly superior to the Andromeda's (this with equalizing!). Unfortunately it's on the way to CA right now – just because of a lost «button» (to be seen on the first picture).
