Marco Angel
Thanks for your opinion and mini-review. Can you say what in-ears u are used to?So today I noticed the FH5 are tip dependent. Fiio provides 4 sets of tips. All of the sets of tips have different size bores depending on the type of sound you prefer. So a bit of a tuning aspect using tips. Narrow 2mm tips for vocal centric sound, about 3mm for balanced and 4mm for bass..I tried all 3 tips and the changes are subtle at best but to be honest I didn't use anything that came with them. Haven't tried the foams that came with them yet.
Settled for a double flange wide bore tip I believe they are brainwavz variety. Can't say tips will have this much influence on the sound of the FH5 for any of you guys as they do for me but. None of the included tips maximizes the sound for me like this particular double flange tip. For one they elongate the sound that is coming out of the 3 bores in the nozzle. Deeper insertion. This seems to make the sound coming out of the FH5 jive better for me.
What I am hearing now. Combination of a upgraded cable and the tip here and I have me a very enjoyable musical full bodied sound coming out of the FH5. I suppose guys have to be good with a bit of vocal forwardness but it don't sound shouty or disjointed, if anything it sounds engaging. Balancing is still there and I get it all. That low hitting full bass end. Smooth sounding vocals with clean instrument placement in the back ground. Speed metal sounds great due to the BAs being fast. Has them crunchy guitars. Bass is surprisingly agile too. The more I am getting to know these the more I am enjoying them.
They have their own sound vs something like the IT04. Differently tuned earphones from different companies and to be honest. I like me a bit of variety. It is refreshing not hearing yet another V shaped earphone in both the FH5 and the IT04.
These are not a neutral signature. You do have to like you some deep hitting bass, a mid range that does not take a step back and treble that is clean yet not overly done for the sake of faking a high end sound. They do provide the one aspect I always look for in an earphone. They are engaging to listen to and if that is worth your money. I say go for it.
Im very hesitating about the FH5, dont know if they are going to have that deep bass the graph shows (maybe is to faint), im not a bass head but love to have my metal/rock music with impact
