the difference is too small to detect by the instrument we used.
After experimenting the new Meze Silver Cable for their Meze 99 Classics Headphones, which I liked quite a bit, I am curious how the silver cables for FH5 would work
There is no scientific proof that a € 100 cable produces better sound than a € 10 cable.
It is like believing that a food of € 100 per kilogram is more nutritious than a € 10 per kilogram.
To be honest, I am trying to lose weight, so I'd rather buy food that has less macro nutrients than more
Hmm? Well, none of the customs I own have a screen over the tubes openings, and I never had a problem with wax clogging those phones up. That's what those tools are for. People should keep their audio investments clean (like cleaning a weapon after hitting the range). Regular maintenance should prevent wax buildup.
This is something I should comment for, even if for a little.
I am taking extreme care of my ears, but my old IE8 still clogged. IT isn't a bit of wax at once, it is repeated usage with small debris, even dust, which can clog the tubes. Even people who are overly clean can have issues with this. The thing is, after my IE8 clogged, I was able to use a toothbrush and brush its metallic mesh, then they were back to new.
I haven't tried to take off the screen of FH5 to see if it makes a different yet, if it makes, then the real answer would be trying to use a better screen which won't make issues.
Not using a screen would mean assuming that all users are incredibly careful and clean with their equipment, and when you sell as much as FiiO, it is best to not assume that. The price of FH5 makes it quite accessible that a lot of people who are not hardcore listeners will get one, if they don't clean and don't practice caution, then it is basically an accident waiting to happen. Of course, when you own a 1K Custom you pretty much read the book on how to clean it, but if FH5 is made for a large public, having some kind of protection might be a really good idea. Since I do not know yet how much of a difference having the screens make, I will not comment more, but an even better solution would be to have the screens detachable
