FiiO FH5 - Quad Driver Hybrid In-Ear Monitors || Knowles Balanced Armature Drivers
Feb 4, 2020 at 10:34 PM Post #2,101 of 2,201
FiiO
Sponsor: FiiO
Guangzhou,China
Hi @FiiO,
I bought the FH5 a few days ago and i love them. The sound difference between the FH5 and Sennheiser IE80 (my old headphones now) is quite remarkable. The sound layering is so good, that i can pin point where every instrument sits and plays. I was worried a little bit about the fitting since they are bigger than the IE80, but i can say that the FH5 are even more comfortable, and ergonomic.
I have one curiosity if you can shed some light.
It is regarding the 2 BA drivers for the high frequencies. As i understand, an electronic crossover is used for every driver. Now, since my hearing and i think i am speaking for majority of users, is maximum 15 khz, i want to know what is the cutoff frequency for these 2 tweeters. I understand that one driver renders, let's say, the lower highs, and the other one, the higher ones (please correct me if i am wrong). I would like to know if the driver that renders the higher frequencies is above or below 15Khz. And if so, by how much.
By the way, as a source, i am using my trusty X3II which works flawlessly from the day i bought it.
Dear user,
I am not sure about the BA driver. But the frequency response of the FH5 is 15Hz-40kHz.
Best regards
Feb 13, 2020 at 11:01 PM Post #2,102 of 2,201
Shoulon
Coming from using Sennheiser IE-80 for well over 8 years (same pair!)
These are absolutely amazing. I still think the IE-80 had better soundstage but the audio quality isn't comparable. These are a league of an upgrade.
Feb 19, 2020 at 10:44 AM Post #2,103 of 2,201
Deolum
Germany
Is it even possible to get these vocal ear tips on the phones? The hole is just too small. Tried it for 10 minutes now.
Feb 20, 2020 at 11:20 PM Post #2,104 of 2,201
FiiO
Sponsor: FiiO
Guangzhou,China
Dear user,
Please try to place the core half over the soundpipe of the product at an angle and apply pressure to the top of the tip to gently roll the rest of the core onto the soundpipe.
Best regards
Feb 22, 2020 at 10:49 AM Post #2,105 of 2,201
Deolum
Germany
Dear user,
Best regards
Thanks for the reply. I mean i did nothing different and all the other tips fit perfect but the vocal tips are just impossible to get on. Maybe it's because it was open boxed and they mixed the vocal tips while refurbishing and put another models tips in? But the foam tips work good for me anyways.
Mar 10, 2020 at 6:37 PM Post #2,107 of 2,201
gto88
I think I made a big mistake about the tips.
The default M size tip doesn't work well, so I started chasing M or S from other brands.
I found some other IEMs work well with default tip and they seem bigger than FH5's, so
I tried L from FH5 package, and it works well and seal well, ran a cycle and back to ground 0.
Mar 10, 2020 at 6:43 PM Post #2,108 of 2,201
genck
Banned
US
That's how it goes with IEM's, due to stem width/length variance among brands you aren't going to have the same size tip on all IEM's unfortunately (for ideal fit).
Apr 22, 2020 at 6:57 AM Post #2,114 of 2,201
HerrXRDS
Has anyone else experienced a reduction in highs with the FH5? I've been using these quite a lot and the highs are no longer as loud. From what I could find there is one damper for the highs installed. The exterior grill was squeaky clean with absolutely no sign of grime, but I figured out maybe sweat and oil got into the nozzle. I left the nozzle soak in hydrogen peroxide for a few minutes, I don't want to use isopropyl alcohol as it might attack the glue and plastic parts. This made a huge difference in sound, it's open and clear again so the damper getting clogged seems to be the problem. Does anyone know the specs of the original damper for a possible replacement?
Jun 8, 2020 at 3:58 AM Post #2,115 of 2,201
steelydave
Is there anyone who's used the double-flange eartips with these that has any reccomendations for something similar that's slightly smaller, or narrower?
The deeper insertion means they're the only ones that really seal for me, but I really have to jam them in to get them to stay, so after a couple of hours of use my delicate slender earholes (if that is such a thing) get sore.
