expatriot
Yes, they test their products, but not with your ears.
The fact that so many people have fitting problems kind of makes your comment irrelevant and unnecessary, maybe you think you are smart and/or funny. You are neither, but hey, keep going if it makes you happy. I also have a M9 which I love but with a long story of problems most of them solved months after its release. Fiio is a good but young brand that can't spend as much money in research as giants like older, more established brands. I understand to a point , but when you spend almost 300 dollars in an IEM, it has to be above the average product and that includes testing.Yes, they test their products, but not with your ears.
Returned mine as well. Don't they test their products?
I couldnt get a good fit. It sounded flat, lifless.
They actually test all their products, and for the most part do a pretty good job. The issue with the FH5 is that it is a shallow fitting IEM with a short nozzle. I wish all IEM manufacturers would make their nozzles slightly longer, but that would only suit "some" ears. Generally with a shallow fitting IEM you'll need a larger size than you'd usually use. I also recommend foam as its harder to seal a wide canal opening with silicone.
Perhaps look at Comply Comfort Series - https://www.complyfoam.com/products/ts-series/
I personally just use Shure Olives and stretch them to fit.
And expat is correct - FiiO can't plan for all ear shapes - same as any other manufacturer. Sad for those of us with non-standard ears. But its reality
ISN H40. Priced at $195. You can check ISN H40 thread for impressions & comparisonsHas anyone moved on from the FH5 to a similarly priced non FiiO IEM? If so, which one?
