HerrXRDS
- Dec 27, 2014
Has anyone tested to see what filter works with these to drop the 2k peak a bit?
What about the FA7 do you recommend versus FH5? From what I was reading FH5 has deeper bass and FA7 a thicker and warmer sound with more mid bass. Which one has better transparency and clarity? I personally like transparency and deep bass and don't like bass that is boomy and dominating so I was thinking I might not like FA7 as much as FH5.
As others have already mentioned, how is insertion depth of the FH7 compared to the FH5?
Adding photo and FR of the mod:
Stock (grey) damper replaced by brown one and micropore with a small hole
Effect of micropore (ignore bass rollof, bad seal).
blue = stock / white = micropore
Percieved changes are actually bigger than seen in FR above, the 2k doesn´t "resonate" anymore, CSD confirms that, but I don´t have accurate rig so uploading it here would be meaningless..
Effect of changing grey damper to brown. You can use some stronger dampers - green or red one, if you still find 7k too prominent, but brown works for me. Great thing about knowles dampers is that in this case it actually attentuates only 4-10kHz withouth affecting air above 10k that much
white = micropore / brown = micropore + brown damper
The small 1.5k bump is from dynamic driver (no crossover..), it can also be tamed as seen few pages back, but I actually prefer it like this.
(previous bunch of measurements)
As you can see, using damper with higher resistance can isolate and bring down the 7khz region, use it only if the treble bothers you.Thank you for suggesting this mod and for providing the photos. I have done the tape mod and it has really helped. My major problem has been the mids, which didn’t sound right to me and were too thin. However, the mids now sound a lot better. How much difference does changing to the brown damper help? Thanks.
I came back to original damper, because I find it balances the bass emphasis better. Imho with brown damper, it sounds more tonally correct, but then the bass becomes more prominent, relatively.
Ideally I´d like to get a tighter bass (rest I can tune myself), but then we´d need to look in FH7/IT04 price category :/
Thanks @Brooko that's exactly what I wanted to see. I won't lie - the reduced bass and hotter treble on the FH7 is a concern, even though I know real-world listening is different to FR. Literally the only thing I would change from the stock FH5 is the 2khz peak by about 3dB, and then only for tracks where it makes already peaky female vocals even more so. Otherwise it's damn near perfect (for me). New cable aside (which I can buy for the FH5 as well), it's increasingly looking like the FH7 is another 'flavour' from FiiO's already-excellent IEM offering; give three people the FH5, FA7 and FH7 and chances are each one will like a different one for different reasons. You're certainly not being short-changed on any of them, SQ-wise.For GLer - and sorry if a little off topic.
Graphs - usual disclaimer (read any of my recent reviews)
- FH7 has same body shape, but much sexier in black
- Cable is a lot nicer.
- Nozzle is about 1mm longer (they are replaceable and have the filters inserted.
Red filter - channel matching is pretty good!
All of the FH7 filters - mostly affects the upper mids and lower treble
FH5 vs FH7 vs FA7
Now remember the FH7 shows least bass, but it also has the bigger DD compared to FH5. The bass on the FH7 is actually really good and goes low where required. Its just not V shaped / in your face. You can see how bad the FA7 is (although admittedly BA bass isn't as impactful as DD). FH5 has a lot of bass - but also has overly heightened upper mid-range.
FH7 is "just right" IMO (red filter), and for those wanting more left, it EQ's really well (if you like to boost bass).
Thanks New cable aside (which I can buy for the FH5 as well), it's increasingly looking like the FH7 is another 'flavour' from FiiO's already-excellent IEM offering.
It holds in there just by friction, so use some needle or something with small tip to gently pull it outFrom what you say, I may give the brown dampers a go. How did you get the dampers out? Thanks for the advice.
If you like FH5, imho you should try to live with it using EQ or the mod I presented earlier. As you said, the price/performance of FH5 is probably a lot better, but this is normal when you approach higher end gear..Thanks @Brooko that's exactly what I wanted to see. I won't lie - the reduced bass and hotter treble on the FH7 is a concern, even though I know real-world listening is different to FR. Literally the only thing I would change from the stock FH5 is the 2khz peak by about 3dB, and then only for tracks where it makes already peaky female vocals even more so. Otherwise it's damn near perfect (for me).
Agree there! Do you have higher-end IEMs to compare the FH5/FH7 with? Andromeda comes to mind. As does IE800/S.Cable makes no difference to frequency response. I've done measurements on other IEMs in the past, and unless the wire massively changes impedance, then there is no measurable or audible change.
Agreed, if I'm going to spend double the cash, I'd want to hear a marked difference, either technically better or at least audibly different. Otherwise there's not much point. The FH5 already has a brilliant build and is super comfortable, so the only thing I'd be looking to enhance is the SQ, and a slight reduction in upper mids is not worth a $250 outlay for me.It holds in there just by friction, so use some needle or something with small tip to gently pull it out
I guess FH7 will be technically better, mainly due to the better DD, but some people may find it lacks bass which is evident when looking at their FR comparison.
I´d definitely want to try these, but I´m not sure I´m ready to spend double the cash compared to my FH5...
Sorry - heard the Andromeda, but don't have it. When I run the review, I can compare with the DK-4001, U10, RE2000, Sirius - maybe a few others.Agree there! Do you have higher-end IEMs to compare the FH5/FH7 with? Andromeda comes to mind. As does IE800/S.
