Dear friend, FH5 max size of the sound tube is 6.5mm. So it's recommended to buy ear tips which inner diameter are between 4-6mm. Best regards
I'm using this one, soft as a shoe lace and lightest I have, the connectors match the colour of the shells too, quite enjoy it. https://m.aliexpress.com/item/32828...cc-472d-9599-619d9798df77&transAbTest=ae803_4
Thanks. It does look very sexy, however I do need angled mmcx connectors. Because of the angle of my ear canals the front of the shells gets angled away from my head so the connectors stick out causing discomfort and look funny
This any good? £26.96 72%OFF | AK OFHC 24 AWG 6N High Purity Copper Cable 2.5/3.5/4.4mm Balanced Earphone Cable With MMCX Connector from Taiwan For HQ8 TIN T2 https://s.click.aliexpress.com/e/Tjf0Yh2
Tested FiiO FH5 FiiO FH5 presented several reports, which are different levels of difficulty. Professional reports contain graphs and tables Simple reports – a description of the characteristics in a simple language On-line comparison and selection services for FiiO FH5
New owner of FH5 (bought 2nd hand for a good price). I'm blown away by what I'm hearing out of my QP1R (with very light EQ on mids). I was telling a friend that's probably the best ratio price/performance I've ever had. (and I had a tons of IEMs). I think that's the 1st time I really like an hybrid IEMs not costing 2K My QP1R is by far a better partner than my ZX300, probably because of the class A power. It plays a major role in the overall SQ quality vs ZX300 (3.5) I'm now very curious about the FH7!
Thanks for the tip mate. The quality is surprisingly good, especially for the price. The connectors are nice and tight. The hooks aren't memory wire but are shorter than Fiio's, which I like. The braid below the Y-split could be a little better but for the price I can't ask for much more. I just hope it doesn't stiffen quickly like my Fiio one.
Thanks gLer, I just order FiiO K3 DSD DAC to use at work. It has 2.5 balance output. I already use upgrade 3.5mm cable from FiiO. So I not sure that 2.5 balance cable from aliexpress will be a good improvement Any cable suggestion, will be very appreciate Thank you very much.
Hi, just order the FiiO LC-2.5B from AliExpress (2.5mm balanced). That’s all you need. https://m.aliexpress.com/item/32913...d=4000amp--3j8yxg8y3a-AFCy2g0GKQ1556486110094
