FiiO F9, F9Pro-Detachable MMCX connector,Hi-Res Audio Certified,2.5mm TRRS/3.5mm audio cable
Dec 3, 2017 at 5:56 PM Post #1,111 of 1,544
Finally i got one it, thank you fiio , it's really impressive :gs1000smile: i had shure215 and in my opinion, f9 pro sound brighter, wider and more bassy.And its comfortable too, i can wear it 2 hours with no trouble, soundproofing is good. Just have one cons i dont like, connecter so hardy, make connect and remove cable little tough.
How does these compare to the regular F9?
Too bad my local reseller doesn't have these in stock yet.
Dec 3, 2017 at 9:00 PM Post #1,112 of 1,544
You don’t need an external amp - they are very easy to drive.
Yes, all our IEMs are quite easy to drive, at the same time it is not so sensitivity to hiss of the source.
Dec 3, 2017 at 9:24 PM Post #1,114 of 1,544
Agreed. Just received the Q1ii a few moments ago. Can’t wait to test the Q1ii together with my X3iii and F9 Pro as well as with my iPhone 6S. Thanks for your hospitality James.
Dec 4, 2017 at 12:46 AM Post #1,117 of 1,544
More new stuff to try and review. Q1ii, RC-MMCXB and a free leather stacking case for Q1ii with iPhone.
Dec 4, 2017 at 4:13 AM Post #1,118 of 1,544
Is the stacking case included with the amp?
Dec 4, 2017 at 4:39 AM Post #1,119 of 1,544
Dec 5, 2017 at 3:52 PM Post #1,125 of 1,544
I enjoy the F9 PRO with the Q1MkII bass boost very much. Without bass raised it is a little too light on bass. EX1000 and others are too so no biggie. Fit....is awesome
Exactly how I felt, esp. compared to the F9s:
I don't measure, just using my ears... :wink:
This is what I found so far:
F9 are easy to drive with good weight in all areas - a little peaky in 7kHz area (easy to eq out).
F9pro are more transparent but have definitely LESS (upper)bass and lower mids! Sub bass is audible though.
So you need to push bass somehow (depending on your source - and I own x5 iii) which is IMO unfortunately more of concern than just lower one specific area.
I own them both (my purchase, cause I was too curious) and offer to compare them using YOUR song samples (name them I'll check with 320s mp3 or provide 'em from your Dropbox or alike).
Cheers ChrisBa
see also
https://www.head-fi.org/threads/rev...ro-in-us-market-is-on-right-now.865106/page-2
