480126
- Jul 20, 2017
@FiiO: What is the difference between the original sym cable - who comes with F9 pro - and the RC-MMCXB? Thanks for your information
Sorry, sym. cable is in german balanced! I want to know what the difference is between bal. original cable F9 Pro and the bal. cable mmcxb!Balanced vs unbalanced.
Hi,@FiiO: What is the difference between the original sym cable - who comes with F9 pro - and the RC-MMCXB? Thanks for your information
Thanks Fiio! From the paper the mmxcb is better! Right?Hi,
You may have a comparasion as followed:
MMCXB:
MMCX2B:
Best regards
Hi,
MMCXB:
MMCX2B:
Best regards
Yes I will selling the original balanced Cable if Fiio F9 pro and the Fiio mmcxb arieved. I think in 10-15 days. If you want buy the cable please make your offer via pm. Thanks and best wishes to UKThis is first time that I have heard of the MMCX2B and I can only find reference to it on Indian sites.
So, are you now selling the MMCX2B (the orginal balanced cable from the updated F9) as a replacement part?
If so, when will it be coming to Europe and the UK, and how much will it cost?
Thanks.
I’ve never heard of the MMCX2B cable before. The RC-MMCXB cable that I got from Fiio is better than the balanced one that came with the F9 Pro. I hear better clarity and better refined bass as well as much better separation. I did AB testing with both cables on same source and track. I can recommend it highly.
Edit : ok I have just verified that the MMXC2B is the exact same balanced cable that comes with the F9/Pro/FH1 and MMCX2 is the single ended cable that comes with them. So the MMCXB cable is the better upgraded one.
My review on the F9 Pro is here - https://www.head-fi.org/showcase/fiio-f9-pro-hybrid-triple-driver-iem.22784/reviews#review-19532
For those wanting the frequency comparison between the Pro and the original:
For that reason I'm thinking FH1, but still zero reviews so far.Eugh, that treble spike is still there. I was hoping they had toned it down a bit. As it currently stands, I can't listen to my F9's without removing the spike through EQ. Oh well, i've cancelled my F9 Pro order - will read around a bit.
